# Google Workspace (Custom) - Delete records action
The Delete records action enables you to delete multiple records in Google Workspace.
| Object | Specify the object to delete records from. Fields load dynamically based on the object you select. |
For example, the following input fields correspond to the Membership object.
| Group email address | Enter the value for the group email address. |
| Group member email address | Provide the group members’ email addresses. |
The output fields are determined by the object selected in the input. Map the relevant datapill from the datatree to subsequent steps.
For example, the following output fields correspond to the Membership object.
| Status | Status of the membership after the delete operation. |
Last updated: 6/3/2025, 6:28:24 PM
