# Google Workspace - New admin activity event trigger
The New admin activity event trigger runs the recipe every time a Google admin performs an activity in Google Workspace, such as creating a new resource in Calendar or changing a Gmail setting for an organizational unit.
Input field Description
When first started, this recipe should pick up events from Enter the date and time when the trigger starts monitoring for events. Refer to Triggers to learn more about this input field.
Event name Locate the Google Workspace app in Google's Admin event names (opens new window) guide to find the event name. Use the value from the Event name row that corresponds with the activity you plan to monitor. For example, to configure the trigger to monitor for new Calendar resources, enter CREATE_CALENDAR_RESOURCE.
Filters Select filters to narrow down the returned list of events. Separate each filer with a comma. Refer to Google's filter parameter (opens new window) guide for more information.
ADDITIONAL INPUT FIELDS
The recipe editor generates additional input fields based on your Event name selection.
The Create object action's output fields vary based on your selected Object type. Refer to Google Workspace's API documentation (opens new window) for more information about the output fields for each type.
Last updated: 3/2/2026, 9:14:16 PM
