# Google cloud storage Connector - Update object metadata
This action will update an object’s metadata in your Google cloud storage instance.d
For uploading object content and metadata use the upload object action.
Field | Description |
Bucket name Required | The name of the bucket to be updated. |
Object name Required | The name of the object to be updated. |
Pre-defined Access Controls | Select a pre-defined access control configuration. |
Projection | Select the set of properties to return. Defaults to No ACL. |
Generation | If present, permanently deletes a specific revision of this object (as opposed to the latest version, the default). |
If generation matches | Makes the operation conditional on whether the object's current generation matches the given value. Setting to 0 makes the operation succeed only if there are no live versions of the object. |
If generation does not match | Makes the operation conditional on whether the object's current generation does not match the given value. If no live object exists, the precondition fails. Setting to 0 makes the operation succeed only if there is a live version of the object. |
If Meta generation matches | Makes the operation conditional on whether the object's current metageneration matches the given value. |
If Meta generation does not match | Makes the operation conditional on whether the object's current metageneration does not match the given value. |
Pre-defined access controls
These are the accepted configurations:
- authenticatedRead: Object owner gets
OWNER
access, and allAuthenticatedUsers getREADER
access. - bucketOwnerFullControl: Object owner gets
OWNER
access, and project workspace admins getOWNER
access. - bucketOwnerRead: Object owner gets
OWNER
access, and project workspace admins getREADER
access. - private: Object owner gets
OWNER
access. - projectPrivate: Object owner gets
OWNER
access, and project workspace members get access according to their roles. - publicRead: Object owner gets
OWNER
access, and allUsers getREADER
access.
Object specific output fields will be dynamically rendered base on the objects you select.
