# LINE WORKS - New event trigger
The New event polling trigger monitors LINE WORKS for an event type you select, such as a user joining a chat room or sending a message in LINE WORKS.
LINE WORKS New event trigger
# How to configure a static webhook trigger
Copy the Webhook endpoint URL from your recipe. You can find it in the help section of the trigger, as shown in the preceding image.
Go to API > Bot.
Select your Bot to open the Bot EDIT pop-up.
LINE WORKS Trigger setup
Click Edit.
Click the Callback URL toggle and paste the Webhook endpoint URL copied in Step 1.
Click Save to finalize the configuration.
Your webhook trigger is now ready to use.
| Input Field | Description |
| Type | Select a LINE WORKS event type from the drop-down list. Refer to LINE WORKS' Callback event types (opens new window) documentation for more information. |
| Bot secret | Enter the Bot secret for your configured bot. |
| Set trigger condition | Specify conditions to filter events that activate the trigger. |
The New event trigger's output fields change dynamically based on the selected object type. Map the relevant datapill from the data tree for downstream steps.
Last updated: 9/23/2025, 8:28:42 PM
