# LINE WORKS - Search record action
The Search records action searches LINE WORKS for an object type you specify.
Line works Search record actionLINE WORKS Search record action
Input Field Description
Object Specify the object type to search for. Additional input fields load dynamically based on the selected object type.
The Search records action's output fields change dynamically based on the selected object type. Map the relevant datapill from the data tree for downstream steps.
On this page
