# Microsoft Dynamics 365 - Monitor changes in entities trigger (batch)
The Monitor Changes in Entities Trigger (Batch) in Microsoft Dynamics 365 monitors changes in entities using delta links and retrieves changes in batches.
Field Description
Entity Select a standard or custom Microsoft Dynamics 365 object to monitor. For example, Lead. Only objects eligible for change tracking are supported.
Output fields Select the fields of the selected objects you plan to use in your recipe. All fields are returned if left blank.
Fetch only new changes? Choose Yes to return only changes in the records after the recipe has started. Defaults to Yes. Recommended to avoid large number of initial jobs.
Batch size Maximum number of records per trigger event. Minimum is 1, maximum is 200, default is 200.
Trigger poll interval Determine how frequently to check for new events. This defaults to five minutes if left blank. The minimum value allowed is five minutes.
Field Description
Range The range of record IDs retrieved from the search.
Records This contains a list of records. Each record contains information about the changed object, including the fields specified in the output fields.
Last updated: 1/19/2026, 4:31:14 PM
On this page
