# Microsoft Dynamics 365 - New object trigger
The New Object trigger in Microsoft Dynamics 365 checks for newly created objects every specified interval and processes each new object as a single trigger event.
| Field | Description |
| Object | Select any standard or custom Microsoft Dynamics 365 object to monitor. For example, Lead. |
| From | Fetch new object from the specified time. |
| Output fields | Select the fields of the selected objects you plan to use in your recipe. All fields are returned if left blank. |
| Filter condition | Condition to filter the records. Use OData $filter syntax. For example, contains(name, 'sample') and revenue gt 1000000. Learn more about filters (opens new window). |
| Change details | This contains information about the new object, including the fields specified in the output fields. |
Last updated: 1/19/2026, 4:31:14 PM
