# Microsoft Dynamics 365 - New object trigger (real-time)
The New Object trigger (real-time) in Microsoft Dynamics 365 triggers immediately when a record is created in Microsoft Dynamics 365.
Field Description
Event name Use a unique name to generate webhook URL.
Object Select any standard or custom Microsoft Dynamics 365 object to monitor. For example, Lead.
From Fetch object from the specified time.
Output fields Select the fields of the selected objects you plan to use in your recipe. All fields are returned if left blank.
Field Description
Change details This contains information about the new object, including the fields specified in the output fields.
Last updated: 1/19/2026, 4:31:14 PM
On this page
