# Microsoft Dynamics Finance and Operations - Create record action
The Create record action enables you to create a record in Microsoft Dynamics Finance and Operations (MSDFO).
Create record actionCreate record action
# Input fields
Input Field Description
Object Specify the object you plan to create. Fields load dynamically based on the object you select.
# Output fields
The output fields are determined by the object you select in the input. Map the relevant datapill from the data tree for downstream steps.
Last updated: 12/11/2025, 6:57:33 PM
