# Microsoft Dynamics Finance and Operations - Create records in batch action
The Create records in batch action enables you to create records in batch in Microsoft Dynamics Finance and Operations (MSDFO).
Create record in batch action
# Input fields
| Input Field | Description |
| Object | Specify the object you plan to create. Fields load dynamically based on the object you select. |
# Output fields
The output fields are determined by the object you select in the input. Map the relevant datapill from the data tree for downstream steps.
Last updated: 12/11/2025, 6:57:33 PM
