# Microsoft Fabric - Update record action
The Update record action enables you to update the specified record in Microsoft Fabric.
Input field Description
Object Specify the object to update its record. Fields load dynamically based on the selected object.
For example, if the selected object is Lakehouse, the input schema is as follows:
Workspace ID Select or enter the ID of the workspace where the item is located.
Lakehouse ID Select or enter the ID of the lakehouse to update.
Display name Enter the name of the lakehouse.
Description Enter the description for the lakehouse.
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps. To take an example of the Lakehouse object, the following are the output fields.
Output field Description
Description Description of the lakehouse.
Display name Name of the lakehouse.
Folder ID ID of the folder where the lakehouse is created.
ID ID of the lakehouse.
Properties Properties of the lakehouse include the following data. Type, Default schema, One lake files path, One lake tables path, SQL endpoint properties, Connection string, ID, Provisioning status.
Item tag The list of tags attached to the lakehouse is any.
Type Type of the item. Lakehouse in this case.
Workspace ID ID of the workspace where the Lakehouse was created.
Status Status of provisioning of the lakehouse.
Last updated: 1/2/2026, 5:56:05 PM
On this page
