# Microsoft Graph API - Get record action
The Get record action retrieves the details of any record, such as a Drive item, using its object ID.
| Object | Select the object you plan to retrieve. Fields load dynamically based on your selected object. |
The output fields generate dynamically based on the object you select. Refer to the Microsoft Graph API (opens new window) documentation for a complete list of outputs.
Last updated: 3/11/2026, 5:23:17 PM
