# Microsoft Graph API - List records action
The List records action lists records based on the object you select in Microsoft Graph API. This action requires a Microsoft Intune license.
Input fields are generated dynamically based on the object you select. The following input fields are common to all objects.
| Object | Select the object to list records for. Options include Detected app and Managed devices. |
Output fields are generated dynamically based on the object you select. Refer to the Microsoft Graph API (opens new window) documentation for a complete list of output fields.
Last updated: 3/11/2026, 5:23:17 PM
