# NetSuite REST - Execute RESTlet script action
Use this action to export or import data in NetSuite.
Learn more about NetSuite RESTlet (opens new window).
| Operation | Select a RESTlet operation to perform from the picklist. Available operations include Import and Export. Export operations use GET methods and Import use POST HTTP methods to interact with RESTlet APIs. |
| Script ID | Provide the RESTlet script ID to perform the operation. You can get the script ID from within your NetSuite instance in Customization > Scripting > Scripts > NetSuite script record. |
| Deployment ID | Provide the RESTlet script deployment ID to perform the operation. Obtain the deployment ID from your NetSuite instance in Customization > Scripting > Scripts > NetSuite script record > Deployments. |
| Request URL parameters | Determine what the URL parameters should be and assign values to them. You can set up these parameters in Workato's graphical UI by clicking Add URL parameter. Then, provide a Label, Data type, and Hint (optional) in the Add new field modal. Alternatively, you can add the request URL parameters manually by providing a JSON description of your schema. |
| Request body parameters | This input field is only available when you perform an Import operation. Click Use JSON to describe your request body parameters in JSON, or click add fields manually to fill out the Add new field modal, determining the Name, Label, Data type, whether the parameter is Optional, and the Hint for each of your parameters. |
| Response type | Determine a response type. You can choose between JSON and plain text. |
| Output schema | Click Use JSON to describe all fields in your response using JSON, or click add fields manually to fill out the Add new field modal, determining the Name, Label, Data type, whether the parameter is Optional, and the Hint for each of your parameters. |
This action does not generate any output data for use in downstream recipe steps.
