# On-prem files - Delete folder action
The Delete folder action deletes an existing on-prem folder. This action fails if the target folder doesn't exist.
| Folder to delete | Select or manually enter the relative path to the folder to delete. |
| Only delete empty folders? | Select whether to skip folders that aren't empty. |
| Path to folder delete | The relative path to the deleted folder. |
