# On-prem files - Upload file action
The Upload file action uploads a file to an existing on-prem folder.
LEGACY ACTION
The On-prem files connector has both Upload file and Upload file (Legacy) actions:
- The Upload file action supports large file sizes and requires an agent version 2.10.2 or later.
- The Upload file (Legacy) action does not support large file sizes and requires an agent version 2.4.2 or later.
| Folder | Select or manually enter the relative path to the folder to upload the file to. |
| File name | Enter the name of the file to upload, including its extension. |
| File contents | Input a File contents datapill or enter the file contents directly. This input field supports streaming. |
| Overwrite existing file? | Select whether to replace the contents of existing files with the same name and extension. If you select No, a new file is created with an incremental number appended to the filename, for example: report_1.csv, report_2.csv, report_3.csv. |
| File path | The path of the file, relative to the base path defined in your connection profile. For example: /my-profile/path/uploaded-file.csv. |
| File name | The name of the file, including its extension. |
| File size (bytes) | The size of the file contents in bytes. |
| Created time | The time the file was created. This value is set by your OS. |
| Last modified time | The time the file was last modified. This value is set by your OS. |
| File existed before upload? | Indicates whether the action replaced the contents of a file with the same name and extension in the selected folder. |
