# Outlook - Delete calendar event action
Use this action to delete a calendar event using the event ID.
Field Description
Shared calendar Provide the email address of the user who owns the shared calendar, so Workato can fetch the shared calendars. For example, [email protected]. If left blank, Workato shows your default calendars.
Calendar Select the calendar you plan to monitor from the list.
Event ID Provide the ID of the event to delete. You can find the event ID in the event URL or use the Search calendar event action to fetch the event and get the ID.
Field Description
Success Indicates whether the event was deleted successfully.
Last updated: 1/19/2026, 4:31:14 PM
On this page
