# PlusOne Solutions - Get record details by ID action
The Get record details by ID action retrieves specific record information from PlusOne Solutions using the record's unique identifier.
| Object | Select the type of object to retrieve. |
Input fields load dynamically based on the selected Object. For example, the input schema is as follows if you select the Company details object:
| Input fields | Description |
| PlusOne Company ID | Provide the unique 13-character identifier assigned to the company in the PlusOne Network. |
| PlusOne Username | Provide the username assigned to the individual making the request. This is used for audit log entries. Leave this field blank to use the email address specified during connection setup. |
Output fields load dynamically based on the selected Object. For example, the output schema is as follows if you select the Company details object:
| PlusOne ID | Unique 13-character identifier assigned to the company in the PlusOne Network. |
| Company Name | Name of the company. |
| DBA | Doing Business As (DBA) name. |
| Tax ID | Tax identifier assigned to the company. |
| Tax ID Type | Type of tax identifier, such as EIN or SSN. |
| Company Type | Type of company structure, such as CC. |
| Minority Type | Minority business classification. |
| URL | Company website URL. |
| State of Incorporation | State where the company is incorporated. |
| PENDOT ID | PENDOT identifier. |
| Primary Location | Indicates whether this is the primary location. |
| Phone Numbers | Array of phone number objects with type, number, and extension. |
| Addresses | Array of address objects with complete address information. |
| Emails | Array of email objects with type and email address. |
| Industries | Array of industry classification objects. |
| Contacts | Array of contact objects with detailed contact information. |
Last updated: 10/6/2025, 4:26:10 AM
