# Positional file tool - Convert flat file to JSON action
Use the Convert flat file to JSON action to parse positional flat files and convert them to structured JSON. This action supports fixed width or dynamic width files, single schema (uniform rows) or multiple schemas (varied row structures), and fixed lists or dynamic lists for column definitions.
The available input fields vary based on your schema configuration.
# Input for files with a single schema
| File content | Provide the content of the positional file to parse. For example, HDR001,JohnSmith,USA20240401. |
| Schema type | Select the schema type that matches your file. Select Single schema if all rows share the same structure. Select Multiple schemas if the file contains rows with different structures. |
| File structure | Select Fixed width if columns use specific delimiters. Select Dynamic width if columns have inconsistent spacing. |
| Output | Define the expected output structure of the file. The parser maps its output to this definition. You can input JSON or add fields manually. |
| Delimiter | Select the character that separates fields in the file. Options include comma (,), space, tab, colon (:), semicolon (;), and pipe (|). Available for Fixed width file structures. |
| Columns | Define the fields in the order they appear in the file. Each entry represents one column in the flat file. Click the ... (ellipses) to choose between a Fixed list or Dynamic list. Use a Fixed list when the total number of items and their content are known. Use a Dynamic list if the number of items and their content depend on another list. If you choose Fixed list, click + Add item to add more fields. |
| Columns source list (Columns) | Input a list datapill. Available for files with column structures that use Dynamic lists. |
| Field name (Columns) | Provide the name for this column in the parsed JSON output. Available for files with column structures that use Dynamic lists. |
| Field name (Columns) (Item #{N}) | Provide the field name for each item in the list. Click + Add item to add more column fields. |
| Start position (Columns) (Item #{N}) | Define the start index position in the flat string for this field. The first character is 0. Available for Dynamic width file structures and files with column structures that use Fixed lists. |
| Length (Columns) (Item #{N}) | Specify the number of characters this field uses in the flat file. Available for Dynamic width file structures and files with column structures that use Fixed lists. |
# Input for files with multiple schemas
Files with multiple schemas require you to select an output structure. The available input fields depend on your selection:
- Linear fields: Produces flat output where all schemas are at the same level
- Child fields: Creates nested output with parent-child relationships between record types
# Common configuration fields
The following input fields are common to Linear and Child field structures.
| Output structure | Select Linear fields for flat output or Child fields for nested output with parent-child relationships between record types. |
# Linear fields configuration
Use these fields when you select Linear fields as your output structure.
| Schema identifier position | Define the position of the schema identifier in each row. |
| Start position (Schema identifier position) | Provide the index where the schema identifier starts in the line. The first character is 0. |
| Length (Schema identifier position) | Enter the number of characters the schema identifier spans. |
| Join schemas? | Select Yes if you want to join rows from different schemas by a unique key in the output. If Yes, define the unique key in the column specification for each schema. |
| Schemas | Define schemas for parsing the flat file. Click ... (ellipses) to choose between a Fixed list or Dynamic list. Use a Fixed list when the schema items and content are known. Use a Dynamic list when the schema items and content depend on another list. |
| Schemas source list (Schemas) | Input a list datapill. Available for schemas configured with a Dynamic list. |
| Schema name (Schemas) | Provide a unique name for this schema. |
| Schema identifier (Schemas) | Provide the identifier value that marks rows belonging to this schema. |
| Column specification (Schemas) | Define the columns for this schema. Click ... (ellipses) to choose between a Fixed list or Dynamic list. Use a Fixed list when the column items and content are known. Use a Dynamic list when the column items and content depend on another list. |
| Column specification source list (Schemas) (Column specification) | Input a list datapill. Available for column specifications configured with a Dynamic list. |
| Field name (Schemas) (Column specification) | Provide the name to assign to this column in the output JSON. |
| Start position (Schemas) (Column specification) | Provide the index where this field starts in the line. The first character is 0. |
| Length (Schemas) (Column specification) | Enter the number of characters this field spans. |
| Is unique key? (Schemas) (Column specification) | Select Yes if this field serves as the unique key for joining schemas. |
# Child fields configuration
Use these fields when you select Child fields as your output structure.
| Row types | Define row types for parsing the flat file. Click ... (ellipses) to choose between a Fixed list or Dynamic list. Use a Fixed list when the row type items and content are known. Use a Dynamic list when the row type items and content depend on another list. |
| Row types source list (Row types) | Input a list datapill. Available for row types configured with a Dynamic list. |
| Schema identifier (Row types) | Provide a unique identifier for this row type schema. |
| Columns (Row types) | Define the columns for this row type. Click ... (ellipses) to choose between a Fixed list or Dynamic list. Use a Fixed list when the column items and content are known. Use a Dynamic list when the column items and content depend on another list. |
| Columns source list (Row types) (Columns) | Input a list datapill. Available for columns configured with a Dynamic list. |
| Field name (Row types) (Columns) | Provide the name to assign to this column in the output JSON. |
| Start position (Row types) (Columns) | Provide the index where this field starts in the line. The first character is 0. |
| Length (Row types) (Columns) | Enter the number of characters this field spans. |
| Child row types (Row types) | Define child row types that are processed after the parent row type. Click ... (ellipses) to choose between a Fixed list or Dynamic list. Use a Fixed list when the child row type items and content are known. Use a Dynamic list when the child row type items and content depend on another list. |
| Child row types source list (Row types) (Child row types) | Input a list datapill. Available for child row types configured with a Dynamic list. |
| Schema name (Row types) (Child row types) | Provide the name of the child schema. Must match one of the defined schema names. |
The output for this action is a JSON object that matches the structure you defined in the Output input field. The format varies based on your configuration:
- Single schema: Flat array of objects, one per row
- Linear fields: Flat array where each object includes its schema identifier
- Child fields: Hierarchical structure with nested parent-child relationships
Last updated: 10/30/2025, 9:13:07 PM
