# Positional file tool - Convert JSON to flat file action
Use the Convert JSON to flat file action to convert JSON data structures into fixed-width positional flat files. You can define field paths, positions, lengths, data types, and formatting rules for each field. This action supports nested structures, arrays, and complex data hierarchies.
| JSON Input | Provide the JSON content you plan to convert to flat file format. |
| Schema | Define schema templates for converting JSON data to flat file format. Each schema defines how to process a specific part of the JSON data. Click ... (ellipses) to choose between a Fixed list or Dynamic list of schemas. Use a Fixed list when the total number of schema items and content is known. Use a Dynamic list if the schema items or content depend on another list. If you choose Fixed list, click + Add schema template to define additional schemas. |
| Schema source list (Schema) | Input a list datapill that contains the schemas for your JSON. Available for schemas configured with a Dynamic list. |
| Schema ID (Schema) | Provide a unique name for this schema, such as header, detail, or customer. |
| JSON field name (Schema) | Provide the JSON key to read for this schema. For example, order, or items. Leave empty to use the current or root object as the key. |
| Is array? (Schema) | Specify whether the JSON field is an array and each item should be processed one at a time. |
| Record type prefix (Schema) | Enter a prefix to identify the record type, such as USER, HDR, or DTL. The record type prefix is automatically added to the start of each line. |
| Field mappings (Schema) | Define how JSON fields map to fixed positions in the flat file output. Click ... (ellipses) to choose between a Fixed list or Dynamic list of field mappings. Use a Fixed list when the total number of field mappings and content is known. Use a Dynamic list if the field mappings depend on another list. If you choose Fixed list, click + Add field to define additional field mappings. |
| Field mappings source list (Schema) (Field mappings) | Input a list datapill that contains field mappings. Available for field mappings configured with a Dynamic list. |
| JSON field name (Schema) (Field mappings) | Provide the JSON key to extract value from. For example, customer_id is extracted from {"customer_id": "12345"} and name is extracted from {"name": "John"}. Leave empty to use the default value. |
| Start position (Schema) (Field mappings) | Enter the start character position in the flat file line. 0 is the first character, while 10 is the second if the first field is 10 characters in length. |
| Field length (Schema) (Field mappings) | Enter the number of characters this field should occupy in the flat file. For example, you can specify that names are 15 characters and account numbers are 12. |
| Data type (Schema) (Field mappings) | Select the data type of your JSON. Specify the correct data type to ensure proper formatting and control how numbers, dates, and text are converted. Use number for IDs, decimal for monetary values, and string for names. |
| Text alignment (Schema) (Field mappings) | Specify how to align the text within the fixed-width field. For example, you can use Left for names, Right for numbers, and Center for headers. |
| Padding character (Schema) (Field mappings) | Provide a character to fill empty space in the fixed-width field. For example, you can use 0 for numbers, space for text, and A for codes. |
| Default value (Schema) (Field mappings) | Provide a default field to use when a JSON field is empty or missing. For example, N/A for missing data, 0 for amounts, or UNKNOWN for missing names. |
| Child schemas (Schemas) | Specify child schemas when you require schema processing in a defined order. Child schemas are processed after the parent schema. Click ... (ellipses) to choose between a Fixed list or Dynamic list of child schemas. Use a Fixed list when the total number of schema items and content is known. Use a Dynamic list if the child schema items or content depend on another list. If you choose Fixed list, click + Add child to define additional child schemas. |
| Child schemas source list (Schemas) (Child schemas) | Input a list datapill that contains child schemas. Available for child schemas configured with a Dynamic list. |
| Schema reference (Schemas) (Child schemas) | Provide the name of another schema defined in this list. |
| Flat file content | The generated flat file content. |
| Individual lines | An array of text strings, where each string represents a single row in the flat file. |
| Total lines | The total number of lines in the flat file. |
Last updated: 10/30/2025, 9:05:32 PM
