# Power BI - Get record details action
The Get record details action retrieves the details of a specified object from a Power BI workspace.
| Object | Select an object. Fields load dynamically based on your selection. |
| ID | Enter the ID of the report or dataset to retrieve. |
| Workspace | Select a workspace from the drop-down menu. |
Output fields depend on the selected object. You can use datapills from the datatree to map values in subsequent steps.
