# S3 Data Lake - Get table definitions action
The Get table definitions action retrieves metadata for a table you specify in the AWS Glue data catalog.
Get table definitionsS3 Data Lake – Get table definitions action
# Input fields
Input field Description
Database name Select the catalog database where the table resides.
Table name Enter the name of the table to retrieve metadata for.
Catalog Select the data catalog where the table is stored. If left blank, AWS uses the default catalog for your account.
Transaction ID Enter the transaction ID to read the table as of a specific transaction state.
Query as of time Specify a timestamp to read the table contents as of that point in time. If omitted, the latest state is used.
Include status details Choose whether to include status details for AWS Glue data catalog view operations.
# Output fields
Output field Description
Table Object containing the full table definition.
Catalog ID The AWS catalog ID that owns the table.
Catalog identifier Alias or identifier for the catalog source.
Create time Timestamp when the table was created.
Created by User or role that created the table.
Database ID Unique ID of the associated database.
Database name Name of the catalog database.
Description Description of the table.
Is multi dialect view Indicates if the table supports multiple dialects.
Is registered with lake formation Shows whether the table is registered with lake formation.
Is row filtering enabled Indicates if row-level filtering is active.
Name Table name.
Parameters Key-value map of table parameters.
Retention Retention period of the table.
Storage descriptor Information about the table's storage format, schema, and location.
Table type Classification of the table.
Update time Timestamp of the most recent update.
Version ID ID for the version of the table definition.
Last updated: 12/11/2025, 6:57:33 PM
