# SAP SuccessFactors LMS - Get object action
The Get object action enables you to retrieve an object in SAP SuccessFactors LMS using its ID.
Get object actionGet object action
Input Field Description
Object Specify the object you plan to create. Fields load dynamically based on the object you select.
ID This is the unique ID assigned to each object, which allows you to update information for a specific object. The label name changes based on the object you select.
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps.
Last updated: 1/19/2026, 4:31:14 PM
On this page
