# SAP SuccessFactors LMS - Search object action
The Search object action enables you to return the list of the objects in SAP SuccessFactors LMS that match the search criteria.
Search object actionSearch object action
Input Field Description
Object Specify the object you plan to create. Fields load dynamically based on the object you select.
Filters Select the fields and their corresponding values along with the correct operator by which you plan to filter the search results. Refer to SAP's documentation (opens new window) for more information.
Page size Specify the number of items that you plan to return in the search output.
Offset Specify the number of items that you plan to skip in the search output.
Count This is a boolean (yes/no) field. If you plan the output to return the total count of items present for an object, select this field as yes. Otherwise, select no.
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps.
Last updated: 1/19/2026, 4:31:14 PM
On this page
