SAP - Send IDoc (Advanced) action
This action allows you to send IDoc to an on-premise SAP system or a SAP system on a server behind the corporate firewall. You must configure IDocs in your SAP system before using this action. This action removes the need for dummy configurations that were previously required for the Legacy Send IDoc action.
MINIMUM OPA VERSION REQUIRED
This action is available only in OPA v28.1 and later. This action is designed to support expected SAP behavior and address advanced use cases.
Action Send IDoc AdvancedSend IDoc (Advanced) action
Input
Field nameDescription
Partner typeChoose a partner type: AD = Address, B = Bank, BP = Benefits Provider, GP = Business Partner, KU = Customer, LI = Vendor, LS = Logical System, US = User.
Partner profileSelect the sender partner number as maintained in transaction WE20.
Message typeSelect the IDoc message type defined in transaction WE20 maintained in the partner number selected in the preceding steps. For example, ORDERS, INVOIC.
Basic type and extensionChoose the appropriate IDoc type and extension configured in SAP for a particular message type selected in the preceding steps.
Wait for SAP to process the IDoc?IDoc is processed asynchronously in SAP. This means you can configure the recipe to wait for the processing to finish before moving on to the next recipe step.
Check IDoc status everyThis field appears if Wait for SAP to process the IDoc is set to Yes. Select how often Workato should call SAP. This is useful when you want to control the workload of your SAP system.
ERROR BEHAVIOR
The Send IDoc (Advanced) action confirms that SAP accepted the IDoc at a technical level. A successful step doesn't indicate that SAP completed business processing. Business failures may surface later through IDoc status tracking rather than as step-level errors. Refer to Error behavior in the SAP RFC connector for details.
IDoc advanced picklistPicklist for selection
Default IDoc parameters
The following are the default values as part of the control record implementation:
Field NameDescriptionDefault valueComments
SNDPRTSender partner typePartner type as set in picklistCan be overridden using EDI_DC40 segment
SNDPRNSender partner numberPartner profile as set in picklistCan be overridden using EDI_DC40 segment
SNDPORSender portWORKATOCan be overridden using EDI_DC40 segment
RCVPRTReceiver partner typeLSCan be overridden using EDI_DC40 segment
RCVPRNReceiver partner numberThe SAP server's partner numberCannot be overridden
RCVPORReceiver portSAP plus systemName or SID. For example, if the systemName is XYZ, the ReceiverPort is SAPXYZCannot be overridden
ARCKEY CANNOT BE OVERRIDDEN
ARCKEY (Key for external message archive) cannot be overridden. It maps to the unique submission ID that enables Workato to track IDoc status. We recommend that you leave this field blank.
