# Delete folder action
This action allows you to delete an entire folder from your SFTP server. The action will fail if the folder is not found at the specified path.
| Folder path | Provide the full path of the folder to delete. Example: /folder1/folder2 |
| Deleted folder path | The full path of the folder that was deleted. |
