# Delete file action
This action deletes a specified file from your SFTP server. The action will fail if the file is not found.
Delete file action
| File path | Provide the complete path of the file you plan to delete, including the file name and file type. Example: /folder1/filename.csv |
| Deleted file path | The full path of the deleted file. |
