# Talent Palette - Import organizations
The Import organizations action imports organizations in bulk in Talent Palette.
| File | Provide the CSV file to import. |
| Type | Select the operation type from the drop-down menu. |
| Update key names | Select the master key from the drop-down menu. This field is dynamically loaded when Update history is selected as Type. |
| Update sub key names | Select the sub key from the drop-down menu. This field will be dynamically loaded when Update history is selected as Type. |
| Code page | Specify the file's character encoding. |
| Processing rule set | Specify the data processing rule set name to apply. |
| Job ID | The Talent Palette ID of the registered job. |
