# TikTok Shop - Search records action
The Search records action retrieves a list of TikTok Shop records that match your search criteria. This action currently only supports the Order object.
| Input Field | Description |
| Page size | The maximum number of records to return in a single response. |
| Sort order | Select whether to sort the records in ascending or descending order. |
| Page token | An opaque token used to retrieve the next page of a paginated result set. |
| Sort field | Select a field to sort results by, such as create_time or update_time. |
| Order status | Specify an order status to filter results by, for example: UNPAID or ON_HOLD. |
| Create time greater than | Specify a Unix timestamp to only show orders created on or after that date and time. |
| Create time less than | Specify a Unix timestamp to only show orders created before that date and time. |
| Update time greater than | Specify a Unix timestamp to only show orders updated on or after that date and time. |
| Update time less than | Specify a Unix timestamp to only show orders updated before that date and time. |
| Shipping type | Select a delivery method to filter results by, such as TIKTOK or SELLER. |
| Buyer user ID | Specify the user ID of a buyer to filter results by. |
| Is buyer request cancel | Filter results by whether the buyer has initiated an order cancellation request. |
| Warehouse IDs | Specify a pickup or sales warehouse ID to filter results by. This field is only applicable if the multi-warehouse feature is enabled in TikTok Shop. |
| Output Field | Description |
| Code | The success or failure message returned in the API response. |
| Message | An object detailing the product prices. |
| Request ID | A unique customer ID. |
| Company | A log of requests. |
| Orders | An object containing details about retrieved records, such as their ID, Shipping type, Status, and the User ID of the buyer. Refer to TikTok Shop's Get Order Detail documentation (opens new window) for more information. |
Last updated: 12/11/2025, 6:57:33 PM
