# UKG Pro (SOAP) - Download report action
The Download report action downloads a preconfigured report from your UKG Pro instance.
Input fields load dynamically based on the selected report.
| Report path | Select the report to retrieve. |
| Delimiter | Select the delimiter for the report from the drop-down menu. Options include XML, Comma-separated values, Tab-separated values, and Space-separated values. |
| Report | The report object. The report is formatted according to the delimiter specified in the action configuration. Use the corresponding Workato tool to parse the report. |
Last updated: 1/8/2026, 10:58:12 PM
