# UKG Pro - New record trigger
This trigger picks up new records in your UKG Pro instance. Each new record is processed as a separate job. It checks for new records once every poll interval.
Input field Description
Object Select the UKG Pro object to monitor:
  • Employee person
  • Employment
Company Select the company to monitor.
When first started, this recipe should pick up events from Employees created after this time will be processed by the recipe. If left blank, the default date will be set to one hour before the recipe is first started. Refer to Triggers to learn more about this input field.
Output field Description
Object-specific fields Record details specific to the object type will be provided as datapills. Refer to the UKG Pro API documentation (opens new window) for more details on the output fields of each object.
On this page
