# UKG Pro - Terminated employees trigger
This trigger picks up terminated employee events. Each termination event is processed as a separate job. It checks for terminated employees once every poll interval.
Input field Description
Company Select the company to monitor.
When first started, this recipe should pick up events from Employees terminated after this time will be processed by the recipe. If left blank, the default date will be set to one hour before the recipe is first started. Refer to Triggers to learn more about this input field.
Output field Description
Employee fields Refer to the UKG Pro API documentation (opens new window) for more information on the employee object.
On this page
