# UKG Pro - New/updated record trigger
This trigger picks up new or updated records in your UKG Pro instance. Each new record is processed as a separate job. It checks for new or updated records once every poll interval.
| Object | Select the UKG Pro object to monitor:
| Company | Select the company to monitor. |
| When first started, this recipe should pick up events from | Employees created after this time will be processed by the recipe. If left blank, the default date will be set to one hour before the recipe is first started. Refer to Triggers to learn more about this input field. |
| Object-specific fields | Record details specific to the object type will be provided as datapills. Refer to the UKG Pro API documentation (opens new window) for more details on the output fields of each object. |
