# Walmart Seller Center - Get record details by ID action
The Get record details by ID action enables you to retrieve details of a specific record in the Walmart Seller Center.
Input field Description
Object Specify the object whose details you plan to retrieve. Fields load dynamically based on the object you select.
The output fields are determined by the object selected in the input. Map the relevant datapill from the datatree to subsequent steps.
On this page
