# Walmart Seller Center - Search records action
The Search records action enables you to retrieve a list of records that match your search criteria in the Walmart Seller Center.
| Object | Specify the object to search. Fields load dynamically based on the object you select. |
The output fields are determined by the object selected in the input. Map the relevant datapill from the datatree to subsequent steps.
