# Generate label action
Use the Generate label action to create a custom label in PDF or ZPL format. You can send the resulting file to a compatible printer to print a shipping label.
| Input fields | Description |
| Payload | Provide the JSON body used to generate a label. See Orderful’s documentation (opens new window) for details on the accepted input. |
| Skip validation | Determine whether to validate the JSON data. Select Yes to skip validating the JSON data or No to validate the provided JSON. |
| Format | Determine the format for the finished label. Available options include PDF and ZPL. |
| Label | The generated label in hexadecimal-encoded bytes. |
Last updated: 9/30/2025, 8:42:53 PM
