# Workato EDI - Get record action
Use the Get record action to retrieve details about a record you specify, such as a Transaction, Transaction message, Organization, Acknowledgment, or Delivery.
Input field Description
Object Use the Object drop-down to select the type of record you plan to retrieve. Available options include Transaction, Transaction message, Organization, Acknowledgment, and Delivery.
Transaction ID Provide the transaction ID of the transaction or transaction message you plan to retrieve.
This field is available when you select the Transaction or Transaction message object.
Expand Specify an object to embed into the response. This field only accepts a message as input.
This field is available when you select the Transaction object.
Acknowledgment ID Provide the transaction ID for the acknowledgment you plan to retrieve.
This field is available when you select the Acknowledgment object.
Delivery ID Provide the delivery ID for the acknowledgment you plan to retrieve.
This field is available when you select the Delivery object.
The output for this action is dynamic and depends on the object retrieved from Orderful.
# Transaction object output
Output field Description
Transaction ID Unique identifier of the transaction.
URL The full API endpoint URL for the transaction resource.
Version API version used. For example, v3.
Sender Object containing details about the sender trading partner.
Interchange control
header (ISA) ID (Sender)
Sender’s interchange control header ID.
Interchange control
header (ISA) ID qualifier (Sender)
Qualifier for the sender’s interchange control header ID.
Test interchange control
Test sender interchange control header ID.
Qualifier for the test sender’s interchange control header ID.
Name (Sender) Name of the sender trading partner.
Receiver Object containing details about the receiver trading partner.
Interchange control
header (ISA) ID (Receiver)
Receiver’s interchange control header ID.
Interchange control
header (ISA) ID qualifier (Receiver)
Qualifier for the receiver’s interchange control header ID.
Test receiver interchange control header ID.
Qualifier for the test receiver’s interchange control header ID.
Name (Receiver) Name of the receiver trading partner.
Type Object describing the transaction type.
Name (Type) Transaction type, such as 850_PURCHASE_ORDER.
Refer to Orderful's documentation for more information about available transaction types (opens new window).
Stream The stream that the transaction belongs to. For example, test refers to your testing environment and live refers to your production environment.
Business number Business number associated with the transaction.
Reference identifiers List of reference identifiers tied to the transaction.
Message Object containing a link to the transaction message.
URL (Message) API endpoint URL for the transaction message.
Validation status Status of EDI validation, such as VALID or INVALID.
Refer to Orderful's documentation for more information about transaction statuses (opens new window).
Delivery status Status of delivery to the trading partner, such as SENT or FAILED.
Acknowledgment status Status of the acknowledgment, such as ACCEPTED or REJECTED.
Created at Timestamp when the transaction was created.
Last updated at Timestamp when the transaction was last updated.
Acknowledgment Object containing a link to the acknowledgment.
URL (Acknowledgment) API endpoint URL for the acknowledgment.
# Transaction message object output
Transaction message Returns the full transaction message of the delivered transaction in JSON. You can map the Transaction message datapill into downstream steps, such as the Convert data format action to convert data into the original EDI format or use another connector like JSON Tools by Workato to parse full message granular datapills.
# Organization object output
Organization ID The unique identifier assigned to the organization in Orderful. Used for scoping trading partners, configurations, and transactions.
Name The organization name.
EDI accounts A list of EDI configurations used for trading partner connections. Each account defines its own ISA IDs and connection context.
EDI account ID (EDI accounts) A unique ID for the EDI account within the organization.
Name (EDI accounts) The name of the specific EDI account, usually referencing the trading partner and use case, such as Buyer or Supplier.
Live Interchange control
header (ISA) ID (EDI accounts)
The ISA ID used in production environments for EDI transactions. Must match the trading partner’s expected value.
Test Interchange control
The ISA ID used in test or onboarding environments. Used for validating EDI flows before going live.
# Acknowledgment object output
URL The full API endpoint for the acknowledgment resource.
Created at The ISO 8601 timestamp indicating when the acknowledgment was processed by Orderful.
Status The final status of the acknowledgment, such as ACCEPTED or REJECTED.
Transaction A nested object containing the original transaction's reference. Typically includes its URL or ID. Allows traceability back to the related document, such as an 850 Purchase Order.
Transaction ID The unique numeric identifier of the original transaction within Orderful.
# Delivery object output
Delivery ID Unique identifier of the delivery.
URL API endpoint URL for the delivery resource.
Status Status of the delivery, such as SENT or FAILED.
Created at Timestamp when the delivery was created.
Last updated at Timestamp when the delivery was last updated.
Send succeeded at Timestamp when the delivery was successfully sent.
Approve Object containing the API link to approve the delivery.
URL (Approve) API endpoint URL for approving the delivery.
Fail Object containing the API URL to fail the delivery.
URL (Fail) API endpoint URL for failing the delivery.
Last updated: 3/27/2026, 6:54:51 PM
