# List transactions from polling bucket action
Use the List transactions from polling bucket action to retrieve transactions from a specific polling bucket (communication channel) in Orderful.
| Bucket ID | Enter the unique identifier of the polling bucket (communication channel) you plan to retrieve transactions from. |
| Limit | Specify the maximum number of transactions to retrieve. The default is 30 and maximum is 100. |
| Message schema | This dynamically returns the output fields based on transaction type. Workato recommends copying the JSON output from this action to build the output schema. |
| Transaction ID | Unique identifier of the transaction. |
| URL | The full API endpoint URL for the transaction resource. |
| Version | API version used. For example, v3. |
| Sender | Object containing details about the sender trading partner. |
| Interchange control header (ISA) ID (Sender) | Sender’s interchange control header ID. |
| Interchange control header (ISA) ID qualifier (Sender) | Qualifier for the sender’s interchange control header ID. |
| Test interchange control header (ISA) ID (Sender) | Test sender interchange control header ID. |
| Test interchange control header (ISA) ID qualifier (Sender) | Qualifier for the test sender’s interchange control header ID. |
| Name (Sender) | Name of the sender trading partner. |
| Receiver | Object containing details about the receiver trading partner. |
| Interchange control header (ISA) ID (Receiver) | Receiver’s interchange control header ID. |
| Interchange control header (ISA) ID qualifier (Receiver) | Qualifier for the receiver’s interchange control header ID. |
| Test interchange control header (ISA) ID (Receiver) | Test receiver interchange control header ID. |
| Test interchange control header (ISA) ID qualifier (Receiver) | Qualifier for the test receiver’s interchange control header ID. |
| Name (Receiver) | Name of the receiver trading partner. |
| Type | Object describing the transaction type. |
| Name (Type) | Transaction type, such as 850_PURCHASE_ORDER.Refer to Orderful's documentation for more information about available transaction types (opens new window). |
| Stream | The stream that the transaction belongs to. For example, test refers to your testing environment and live refers to your production environment. |
| Business number | Business number associated with the transaction. |
| Reference identifiers | List of reference identifiers tied to the transaction. |
| Message | Object containing a link to the transaction message. |
| href (Message) | API endpoint URL for the transaction message. |
| Validation status | Status of EDI validation, such as VALID or INVALID.Refer to Orderful's documentation for more information about transaction statuses (opens new window). |
| Delivery status | Status of delivery to the trading partner, such as SENT or FAILED.Refer to Orderful's documentation for more information about transaction statuses (opens new window). |
| Acknowledgment status | Status of acknowledgment, such as ACCEPTED or REJECTED.Refer to Orderful's documentation for more information about transaction statuses (opens new window). |
| Created at | Timestamp when the transaction was created. |
| Last updated at | Timestamp when the transaction was last updated. |
| Acknowledgment | Object containing acknowledgment details. |
| URL (Acknowledgment) | API endpoint URL for the acknowledgment, if available. |
| Delivery | Object containing delivery details. |
| Delivery ID (Delivery) | Unique identifier of the delivery. You can map the Delivery ID datapill into the Approve delivery or Fail delivery actions to approve or fail a delivery. |
| URL (Delivery) | API endpoint URL for the delivery. |
| Approve (Delivery) | Object containing the API endpoint URL to approve the delivery. |
| URL (Approve) | API endpoint URL to approve the delivery. |
| Fail (Delivery) | Object containing the API endpoint URL to fail the delivery. |
| URL (Fail) | API endpoint URL to fail the delivery. |
Last updated: 9/25/2025, 11:20:18 PM
