# Workato EDI - Search records action (batch)
Use the Search records action (batch) to search for transactions or relationships in Orderful.
The input fields are dynamic and depend on the object you select.
# Transaction object input fields
| Object | Use the Object drop-down to select the type of record to search for, such as Transaction or Relationship. |
| Delivery status | Provide the delivery status. |
| Acknowledgment status | Provide the acknowledgment status. |
| Sender interchange control header (ISA) ID | Enter the sender’s ISA ID. |
| Receiver interchange control header (ISA) ID | Enter the receiver’s ISA ID. |
| Reference identifier | Enter a reference identifier for filtering or lookup. |
| Previous cursor | Provide the pagination token returned by the previous response. |
| Next cursor | Provide the pagination token returned by the next response. |
| Stream | Provide the transaction stream. |
| Sender interchange reference identifier | Enter the sender’s interchange reference identifier. |
| Sender group reference identifier | Enter the sender’s group reference identifier. |
| Sender transaction reference identifier | Enter the sender’s transaction reference identifier. |
| Receiver interchange reference identifier | Enter the receiver’s interchange reference identifier. |
| Receiver group reference identifier | Enter the receiver’s group reference identifier. |
| Receiver transaction reference identifier | Enter the receiver’s transaction reference identifier. |
# Relationship object input
| Limit | Provide the maximum number of items to return. |
| Auto send | Enable or disable automatic sending of the request. |
# Transaction object output
| Transactions | This object contains all transactions that meet your search criteria. |
| Transaction ID | Unique identifier of the transaction. |
| URL | API endpoint URL for the transaction resource. |
| Version | API version used. For example, v3. |
| Sender | Object containing details about the sender trading partner. |
| Interchange control header (ISA) ID (Sender) | Sender’s interchange control header ID. |
| Interchange control header (ISA) ID qualifier (Sender) | Qualifier for the sender’s interchange control header ID. |
| Test interchange control header (ISA) ID (Sender) | Test sender interchange control header ID. |
| Test interchange control header (ISA) ID qualifier (Sender) | Qualifier for the test sender’s interchange control header ID. |
| Name (Sender) | Name of the sender trading partner. |
| Receiver | Object containing details about the receiver trading partner. |
| Interchange control header (ISA) ID (Receiver) | Receiver’s interchange control header ID. |
| Interchange control header (ISA) ID qualifier (Receiver) | Qualifier for the receiver’s interchange control header ID. |
| Test interchange control header (ISA) ID (Receiver) | Test receiver interchange control header ID. |
| Test interchange control header (ISA) ID qualifier (Receiver) | Qualifier for the test receiver’s interchange control header ID. |
| Name (Receiver) | Name of the receiver trading partner. |
| Type | Object describing the transaction type. |
| Name (Type) | Transaction type, such as 850_PURCHASE_ORDER. Refer to Orderful's documentation for more information about available transaction types (opens new window). |
| Stream | The stream that the transaction belongs to. For example, test refers to your testing environment and live refers to your production environment. |
| Business number | Business number associated with the transaction. |
| Reference identifiers | List of reference identifiers tied to the transaction. |
| Message | Object containing a link to the transaction message. |
| href (Message) | API endpoint URL for the transaction message. |
| Validation status | Status of EDI validation, such as VALID or INVALID. Refer to Orderful's documentation for more information about transaction statuses (opens new window). |
| Delivery status | Status of delivery to the trading partner, such as SENT or FAILED. Refer to Orderful's documentation for more information about transaction statuses (opens new window). |
| Acknowledgment status | Status of acknowledgment, such as ACCEPTED or REJECTED. Refer to Orderful's documentation for more information about transaction statuses (opens new window). |
| Created at | Timestamp when the transaction was created. |
| Last updated at | Timestamp when the transaction was last updated. |
| Acknowledgment | Object containing a link to the acknowledgment. |
| URL (Acknowledgment) | API endpoint URL for the transaction acknowledgment. |
# Relationship object output
| Relationship | This object contains all relationships that match your search criteria. |
| Relationship ID | Unique identifier of the relationship. |
| Created at | Timestamp when the relationship was created. |
| Updated at | Timestamp when the relationship was last updated. |
| EDI account ID (Sender) | The sender’s EDI account ID. |
| Live Interchange control header (ISA) ID (Sender) | The live ISA ID for the sender. |
| Test Interchange control header (ISA) ID (Sender) | The test ISA ID for the sender. |
| Organization name (Sender) | The sender’s organization name. |
| EDI account name (Sender) | The sender’s EDI account name. |
| Organization ID (Sender) | The sender’s organization ID. |
| EDI account ID (Receiver) | The receiver’s EDI account ID. |
| Live Interchange control header (ISA) ID (Receiver) | The live ISA ID for the receiver. |
| Test Interchange control header (ISA) ID (Receiver) | The test ISA ID for the receiver. |
| Organization name (Receiver) | The receiver’s organization name. |
| EDI account name (Receiver) | The receiver’s EDI account name. |
| Organization ID (Receiver) | The receiver’s organization ID. |
| Transaction type | Object describing the transaction type. |
| Name (Transaction type) | The transaction type, such as 850_PURCHASE_ORDER. |
| Status | The current status of the relationship. |
| Auto send | Indicates whether automatic sending is enabled for transactions. |
Workday
Last updated: 1/16/2026, 4:23:47 PM
