# Connect to NetSuite2
NETSUITE SETUP REQUIREMENT
NetSuite2 connections use the SuiteAnalytics Connect service. Ensure this feature is enabled in your NetSuite account before creating the connection.
Refer to NetSuite documentation (opens new window) for steps to enable the Connect Service feature.
Complete the following steps to connect to NetSuite2 as a data pipeline source. This connection allows the pipeline to extract and sync data from NetSuite2.
Select Create > Connection.
Search for and select NetSuite2 on the New connection page.
NetSuite2 connection setupNetSuite2 connection setup
Enter the Server Datasource. This is the NetSuite server datasource assigned to your account.
Enter the Server Name. This is the specific server that hosts your NetSuite instance.
Enter any required Custom Properties. These are additional properties defined in your NetSuite connector setup.
Enter your User credentials. This field accepts the NetSuite user ID used for integration access.
Enter your Password for the NetSuite account.
Click Connect to verify and establish the connection.
Last updated: 11/5/2025, 6:18:08 PM
