# Connect to Salesforce
Complete the following steps to connect to Salesforce as a data pipeline source. This connection allows the pipeline to extract data from Salesforce.
Workato supports only OAuth 2.0 connections for data pipelines. JWT-based authentication isn't currently supported.
Select Create > Connection.
Search for and select Salesforce on the New connection page.
Salesforce connection setup
Use the Sandbox drop-down menu to specify whether the connection is a sandbox account.
Select OAuth 2.0 as the Auth type. This is the default and only supported authentication method for data pipelines.
Optional. Expand Advanced settings to configure advanced connection options.
Optional. Select a Custom OAuth profile to restrict the connection to specific scopes. This ensures the authentication flow uses the client app linked to the custom profile.
Select Connect and enter your Salesforce account credentials when prompted.
Log in to your Salesforce account
Select Log In to verify the connection.
Last updated: 8/18/2025, 2:14:24 PM
