# Connect to a source and destination for data pipelines
Data pipelines require a source to extract data and a destination to store replicated data. Set up both connections before you configure a pipeline.
After you configure connections, proceed to the Configure a data pipeline guide to set up and define sync settings.
# Supported sources and destinations
Data pipelines extract data from the following sources:
- Salesforce
- NetSuite2
- Marketo
- Jira
- Coupa
- ServiceNow
- Event streams
- File sources
Data pipelines move data to the following destinations:
- Snowflake
- Databricks
- Google BigQuery
- SQL Server
- Data lakehouses such as Iceberg or Delta Lake
LIMITED AVAILABILITY
Workato supports the following data pipeline sources and destinations. Use these guides to configure each connection:
- Connect to Salesforce
- Connect to NetSuite2
- Connect to Marketo
- Connect to Jira
- Connect to Coupa
- Connect to Snowflake
- Connect to Databricks
Contact your Workato representative for information.
Last updated: 8/18/2025, 5:05:32 PM
