# Agent Studio
The Agent Studio APIs allow you to programmatically create and manage Agent Studio assets, such as genies, knowledge bases, and skills.
# Rate limits
Agent Studio resources have the following rate limits:
Type Resource Limit
GETList genies:
/api/agentic/genies
1,000 requests per minute
GETGet a genie by ID:
/api/agentic/genies/:id
AllAll other genie endpoints60 requests per minute
GETList Knowledge bases:
/api/agentic/knowledge_bases
GETGet a Knowledge base by ID:
/api/agentic/knowledge_bases/:id
AllAll other Knowledge bases
endpoints
GETList Skills:
/api/agentic/skills
GETGet a skill by ID:
api/agentic/skills/:id
AllAll other Skills endpoints60 requests per minute
# Quick reference
Type Resource Description
GET /api/agentic/genies Returns a list of genies.
POST /api/agentic/genies Creates a new genie.
PUT /api/agentic/genies/:id Updates an existing genie.
GET /api/agentic/genies/:id Returns the genie associated with the ID you specify.
DELETE /api/agentic/genies/:id Deletes a genie.
POST /api/agentic/genies/:id/start Starts the genie associated with the ID you specify.
POST /api/agentic/genies/:id/stop Stops the genie associated with the ID you specify.
POST /api/agentic/genies/:id/assign_skills Assigns skills to the genie associated with the ID you specify.
POST /api/agentic/genies/:id/remove_skills Removes skills from the genie associated with the ID you specify.
POST /api/agentic/genies/:id/assign_knowledge_bases Assigns knowledge bases to the genie associated with the ID you specify.
POST /api/agentic/genies/:id/remove_knowledge_bases Removes knowledge bases from the genie associated with the ID you specify.
POST /api/agentic/genies/:id/assign_user_groups Assigns user group access to the genie associated with the ID you specify.
POST /api/agentic/genies/:id/remove_user_groups Removes user group access from the genie associated with the ID you specify.
GET /api/agentic/knowledge_bases Returns a list of knowledge bases.
POST /api/agentic/knowledge_bases Creates a new knowledge base.
GET /api/agentic/knowledge_bases/:id Returns the knowledge base associated with the ID you specify.
PUT /api/agentic/knowledge_bases/:id Updates an existing knowledge base.
DELETE /api/agentic/knowledge_bases/:id Deletes a knowledge base.
GET /api/agentic/knowledge_bases/:id/data_sources Returns the data sources associated with the knowledge base ID you specify.
GET /api/agentic/knowledge_bases/:id/recipes Returns the recipes associated with the knowledge base ID you specify.
GET /api/agentic/skills Returns a list of skills.
POST /api/agentic/skills Creates a new skill.
GET /api/agentic/skills/:id Returns the skill associated with the ID you specify.
# Genies
# List genies
# Query parameters
Name Type Description
folder_id string
optional
The ID of the folder where the genie resides.
project_id string
optional
The ID of the project where the genie resides.
state string
optional
The state of the genie. For example: active or inactive.
page integer
optional
Page number of the genies to fetch. Minimum value is 1.
per_page integer
optional
Number of genies to return in a single page. Minimum value is 1. Maximum value is 50.
# Sample request
curl  -X GET "https://www.workato.com/api/agentic/genies?per_page=10&page=1" \
# Sample response
      "id": "gni-BWLSPX4z-BaT3D9",
      "name": "Customer Support Genie",
      "description": "Handles customer support inquiries and provides quick responses.",
      "state": "stopped",
      "folder_id": 22991030,
      "instructions": "You are a helpful, friendly support agent who answers customer questions clearly and politely.",
      "ai_provider": "open_ai",
      "chat_interface": "slack",
      "skills_count": 5,
      "knowledge_bases_count": 3,
      "user_groups_count": 0,
      "active_recipes_count": 0,
      "inactive_skills_count": 5,
      "logo_url": "https://example.com/logo.png",
      "created_at": "2025-07-15T11:07:34.060-07:00",
      "updated_at": "2026-02-24T08:38:29.099-08:00"
      "id": "gni-ZWSMPR4a-TaG7S9",
      "name": "Customer Support Genie v2",
      "description": "Updated to handle billing inquiries in addition to general support.",
      "state": "stopped",
      "folder_id": 21285720,
      "instructions": "You are a knowledgeable, polite support assistant. Always prioritize clear, concise answers.",
      "skills_count": 5,
      "created_at": "2026-02-24T08:54:34.585-08:00",
      "updated_at": "2026-02-25T09:34:14.013-08:00"
# Create a genie
# Payload
name string
required
The name of the genie.
description string
required
A description of the genie's purpose.
folder_id string
required
instructions string
required
The instructions your genie uses to identify its purpose, personality, and job description.
ai_provider string
required
The AI provider that powers your genie. Accepted values are anthropic or open_ai.
shared_account_id integer
required
The Connection ID of your genie.
custom_oauth_key_id integer
required
Custom OAuth key ID.
matrix boolean
required
Determines whether Workato GO is enabled as your chat interface or not. Accepted values are true or false.
# Sample request
curl -X POST https://www.workato.com/api/agentic/genies \
     -d '{
           "folder_id": "7498",
           "shared_account_id": 1234,
           "custom_oauth_key_id": 5678,
           "matrix": true
# Sample response
  "id": ngi-BWLSPX4z-BaT3D9/,
# Update a genie
# Query parameters
id string
required
The ID of the genie you plan to update.
name string
optional
description string
optional
folder_id string
optional
instructions string
optional
ai_provider string
optional
optional
optional
matrix boolean
optional
# Sample request
curl -X PUT https://www.workato.com/api/agentic/genies/101 \
     -d '{
           "matrix": false
# Sample response
  "project_id": "4567",
  "matrix": false
# Get a genie by ID
# Query parameters
id string
required
The ID of the genie you plan to retrieve.
# Sample request
curl -X GET https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9 \
# Sample response
  "state": "stopped",
  "project_id": 93761783,
  "skills_count": 5,
  "connection_id": null,
  "folders": [
          "id": 21285720,
          "name": "Customer Assistants"
  "user_groups": [],
  "created_at": "2026-02-24T08:54:34.170-08:00",
  "updated_at": "2026-02-25T09:34:14.300-08:00"
# Delete a genie
Deletes a genie.
# Query parameters
id string
required
The ID of the genie you plan to delete.
# Sample request
curl -X DELETE https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9 \
# Sample response
    "success": "true"
# Start a genie
# Query parameters
id string
required
The ID of the genie you plan to start.
# Sample request
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/start \
# Sample response
  "success": true
# Stop a genie
# Query parameters
id string
required
The ID of the genie you plan to stop.
# Sample request
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/stop \
# Sample response
  "success": true
# Assign a skill to a genie
# Query parameters
id string
required
The ID of the genie you to which you plan to assign skills.
# Payload
skill_ids array of string
required
An array of skill IDs to assign to a genie.
# Sample request
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/assign_skills \
     -d '{
           "skill_ids": ["65001201", "65704499", "65039789"]
# Sample response
    "skills": [
      "id": "65001201",
      "name": "Sales Lead"
      "id": "65704499",
      "name": "Ticket Escalation"
      "id": "65039789",
      "name": "Order Tracking"
# Remove a skill from a genie
Removes a skill from the genie associated with the ID you specify.
# Query parameters
id string
required
The ID of the genie you from which you plan to remove skills.
# Payload
required
An array of skill IDs to remove from a genie.
# Sample request
     -d '{
           "skill_ids": ["65001201", "65704499"]
# Sample response
    "skills": [
      "id": "65001201",
      "id": "65704499",
# Assign a knowledge base to a genie
# Query parameters
id string
required
The ID of the genie you to which you plan to assign knowledge bases.
# Payload
knowledge_base_ids array of string
required
An array of knowledge base IDs to assign to a genie.
# Sample request
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/assign_knowledge_bases \
     -d '{
           "knowledge_base_ids": ["kb-WSm8kore-blMxrh", "kb-ATx0crok-saMvba"]
# Sample response
    "knowledge_bases": [
      "id": "kb-WSm8kore-blMxrh",
      "name": "Sync Jira"
      "id": "kb-ATx0crok-saMvba",
      "name": "PRD sync"
# Remove a knowledge base from a genie
Removes a knowledge base from the genie associated with the ID you specify.
# Query parameters
id string
required
The ID of the genie you from which you plan to remove knowledge bases.
# Payload
required
An array of knowledge base IDs to remove from a genie.
# Sample request
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/remove_knowledge_bases \
     -d '{
           "knowledge_base_ids": ["kb-WSm8kore-blMxrh"]
# Sample response
      "name": "Sync Jira"
# Assign a user group to a genie
# Query parameters
id string
required
The ID of the genie you to which you plan to assign user group access.
# Payload
user_group_ids array of string
required
An array of user group IDs to add to a genie.
# Sample request
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/assign_user_groups \
     -d '{
           "user_group_ids": ["ertXU2Z3sQaL47T8PssX2V, gpzHU1Y3mJaG77W1JbbZ2B"]
# Sample response
    "user_groups": [
      "id": "ertXU2Z3sQaL47T8PssX2V",
      "name": "Sales"
      "id": "gpzHU1Y3mJaG77W1JbbZ2B",
      "name": "Finance"
# Remove a user group from a genie
# Query parameters
id string
required
The ID of the genie you from which you plan to remove user group access.
# Payload
required
An array of user group IDs to remove from a genie.
# Sample request
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/remove_user_groups \
     -d '{
           "user_group_ids": ["ertXU2Z3sQaL47T8PssX2V"]
# Sample response
    "user_groups": [
      "name": "Sales"
# Knowledge bases
# List knowledge bases
# Query parameters
folder_id string
optional
The ID of the folder where the knowledge base resides.
project_id string
optional
The ID of the project where the knowledge base resides.
query string
optional
Search query.
page integer
optional
Page number of the knowledge base to fetch. Minimum value is 1.
per_page integer
optional
Number of knowledge bases to return in a single page. Minimum value is 1. Maximum value is 50.
sort_term string
optional
The field or term to sort results by. For example: name or latest_activity.
# Sample request
curl -X GET https://www.workato.com/api/agentic/knowledge_bases \
     -d '{
           "per_page": 10,
           "page": 1,
           "sort_term": "name"
# Sample response
    "name": "Support FAQs",
    "description": "Knowledge base with frequently asked customer support questions.",
    "id": "kb-BLm8cove-brMxrh",
    "name": "Sales Playbook",
    "description": "Guidelines and resources for the sales team.",
    "folder_id": "7302",
    "project_id": "9876"
# Create a knowledge base
# Payload
name string
required
The name of the knowledge base.
description string
required
A description of the knowledge base.
folder_id string
required
source_type string
required
The source of the knowledge base, such as a recipe.
data_sources string
required
Configure data sources for the knowledge base.
# Sample request
curl -X POST https://www.workato.com/api/agentic/knowledge_bases \
     -d '{
           "source_type": "recipe",
           "data_sources": "zendesk_articles"
# Sample response
  "id": "kb-BRm8coke-rhMxsa",
# Get a knowledge base by ID
# Query parameters
id string
required
The ID of the knowledge base you plan to retrieve.
# Sample request
curl -X GET https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxrh \
# Sample response
# Update a knowledge base
# Query parameters
id string
required
The ID of the knowledge base you plan to update.
name string
optional
description string
optional
The description of the knowledge base.
folder_id string
optional
data_sources object
optional
The configured data sources for the knowledge base.
# Sample request
curl -X PUT https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxrh \
     -d '{
           "name": "Support FAQs v2",
           "description": "Updated to include billing FAQs in addition to support.",
           "data_sources": {
             "zendesk_articles": true,
             "internal_docs": true
# Sample response
  "data_sources": {
# Delete a knowledge base
# Query parameters
id string
required
The ID of the knowledge base you plan to delete.
# Sample request
curl -X DELETE https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxrh \
# Sample response
    "success": "true"
# Get knowledge base data sources
# Query parameters
id string
required
The ID of the knowledge base for which you plan to retrieve data sources.
# Sample request
curl -X GET https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxrh/data_sources \
# Sample response
  "knowledge_base_id": "kb-WSm8kore-blMxrh",
  "data_sources": {
    "internal_docs": true,
    "slack_channels": false
# Get knowledge base recipes
# Query parameters
id string
required
The ID of the knowledge base for which you plan to retrieve associated recipes.
query string
optional
Search query.
page integer
optional
per_page integer
optional
sort_term string
optional
# Sample request
curl -X GET https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxr/recipes \
     -d '{
           "per_page": 10,
           "page": 1,
           "sort_term": "name"
# Sample response
    "id": 45246391,
    "name": "Customer Support Escalation",
    "description": "Routes high-priority Zendesk tickets to Slack.",
    "knowledge_base_id": "kb-WSm8kore-blMxr/recipes"
    "id": 87654321,
    "name": "Billing Notifications",
    "description": "Sends alerts for overdue invoices to the finance team.",
# Skills
# List skills
# Query parameters
folder_id string
optional
project_id string
optional
query string
optional
Search query.
page integer
optional
per_page integer
optional
sort_term string
optional
# Sample request
curl -X GET https://www.workato.com/api/agentic/skills \
     -d '{
           "per_page": 10,
           "page": 1,
           "sort_term": "name"
# Sample response
    "id": 65001201,
    "name": "Zendesk Ticket Management",
    "description": "Skill for handling customer support tickets from Zendesk.",
    "id": 65039789,
    "name": "Slack Notifications",
    "description": "Skill for sending targeted Slack alerts.",
# Create a skill from an existing recipe
Converts an existing recipe into a skill. The recipe must use a Genie trigger with defined inputs and actions. Call this endpoint with the recipe_id to register the recipe as a skill in Agent Studio.
# Payload
recipe_id integer
required
The ID of the recipe to convert into a skill.
# Sample request
curl -X POST https://www.workato.com/api/agentic/skills \
     -d '{
           "recipe_id": 65039789
# Sample response
  "name": "Customer Escalation Skill",
  "description": "Skill automatically routes high-priority Zendesk tickets to Slack.",
  "recipe_id": 65039789,
# Get a skill by ID
# Query parameters
id string
required
The ID of the skill for you plan to retrieve.
# Sample request
curl -X GET https://www.workato.com/api/agentic/skills/65039789 \
# Sample response
Last updated: 4/15/2026, 9:32:20 AM
