# Developer API - Role-based access control
EARLY ACCESS FEATURE
This documentation covers a feature currently in limited preview. The access control model is under active development and may change. To participate in early access testing, contact your Customer Success Manager to add you to the early adopters list.
Workato has introduced a new access control model that replaces legacy system and custom roles. This model separates permissions into environment roles and project roles to support flexible and environment-specific access control. Refer to the Manage workspace collaborators with role-based access control guide for more information on the new model.
Refer to the following sections to manage collaborators and roles using the Workato Developer API:
Refer to the Embedded API - Role-based access control guide to manage collaborators and roles in customer workspaces using the Embedded API.
# Collaborators
Use the following endpoints to manage collaborators.
API CLIENT ACCESS
API clients require access to the DEV environment to manage collaborators. Refer to Create a client role to configure an API client's access.
# Quick reference
Type Resource Description
POST /api/member_invitations Invite a collaborator to a workspace.
GET /api/members/ Get list of collaborators.
GET /api/members/:id Get collaborator details.
PUT /api/members/:id Update collaborator roles.
DELETE /api/members/:id Delete a collaborator.
GET /api/members/:id/project_grants List a workspace's project grants.
GET /api/members/:id/privileges Get collaborator privileges.
GET /api/members/:id/projects_privileges Get collaborator projects privileges.
# Invite a collaborator
EXISTING ENDPOINT
The following is an existing endpoint with new updates in this release.
Invite a collaborator to your workspace. The API sends an email invitation if the email you provide doesn't belong to an existing user. Collaborators can join the workspace after they create a Workato account. You can invite a specific email and workspace combination once every twenty minutes.
# Query parameters
NEW PARAMETERS
This endpoint now supports the env_roles[role_type] and user_group_ids parameters.
Name Type Description
name string
required
The name of the collaborator.
email string
required
The email of the collaborator.
env_roles object
required
Defines the collaborator's environment roles.
env_roles[environment_type] string
required
The type of environment in the workspace where you plan to invite the collaborator. Use dev for single-environment workspaces.
env_roles[name] string
required
The role to assign the collaborator for the specific environment.
env_roles[role_type] string
optional
The type of role to assign the collaborator. Accepted values include privilege_group and environment. The default value is privilege_group.
role_name string
deprecated
This field is deprecated. Use env_roles instead, even for single-environment workspaces.
user_group_ids array of strings
optional
The IDs of collaborator groups to assign.
# Sample request
curl -X POST 'https://www.workato.com/api/member_invitations' \
  -d '{
        "name": "Josh",
        "email": "[email protected]",
        "user_group_ids": [
          "am-WxEKCibh-dTXBtz",
          "am-APNHJbmM-hfhTD8"
        "env_roles": [
            "environment_type": "dev",
            "name": "Admin",
            "role_type": "privilege_group"
# Response
    "result": "ok"
# Get list of collaborators
EXISTING ENDPOINT
Retrieve a list of all collaborators in a workspace.
GET /api/members
# Query parameters
email string
optional
Filters the list to collaborators whose email contains the provided value. Special characters must be URL-encoded.
# Sample request
curl  -X GET 'https://www.workato.com/api/members?email=example.com' \
# Response
  "data": [
      "id": 12345,
      "grant_type": "federation_manager",
      "user_groups": [
          "id": "am-WxEKCibh-dTXBtz",
          "name": "All collaborators",
          "system": true
          "id": "am-WxEKCibh-dTXBtg",
          "name": "Developers",
          "system": false
      "roles": [
          "role_name": "Admin",
          "environment_type": "test",
          "environment_type": "prod",
      "last_activity_log": {
        "id": 2807129,
        "event_type": "user_login",
        "created_at": "2024-03-07T16:38:18.414-08:00"
      "external_id": null,
      "name": "Rosario",
      "time_zone": "Pacific Time (US & Canada)",
      "created_at": "2021-12-14T13:01:15.935-08:00"
      "id": 23456,
      "grant_type": "team",
      "user_groups": [
          "system": true
          "system": false
      "roles": [
          "role_name": "IT_Developer",
          "role_name": "No access",
        "id": 2807129,
      "name": "Noam",
      "created_at": "2021-1-12T13:01:15.935-08:00"
  "total": 2
New properties
The following properties are new additions to the API response:
  "data": [
      // ...existing response...
      "user_groups": [
          "name" : "All collaborators",
          "system": true
          "name" : "Developers",
          "system": false
      "roles": [
   // ...second collaborator....
  "total": 2
# Get collaborator details
EXISTING ENDPOINT
Retrieves a collaborator by their ID.
# Path parameters
id string
required
The ID of the collaborator to retrieve.
# Sample request
curl  -X GET 'https://www.workato.com/api/members/34567' \
# Response
  "data": {
    "id": 34567,
    "user_groups": [
        "system": true
        "system": false
    "roles": [
        "role_name": "HR_Developer",
        "role_name": "HR_Viewer",
        "role_name": "Operator",
      "id": 2807147,
      "created_at": "2024-03-07T16:44:39.318-08:00"
    "name": "Dana",
    "created_at": "2019-09-09T00:45:17.019-07:00"
New properties
  "data": {
    "user_groups": [
        "system": true
        "system": false
    "roles": [
# Update collaborator roles
EXISTING ENDPOINT
Updates an existing collaborator's roles by their ID. To remove a collaborator's access, include NoAccess in the request payload.
# Path parameters
id string
required
The ID of the collaborator whose roles you plan to update.
# Query parameters
NEW PARAMETERS
This endpoint now supports the env_roles[role_type] parameter.
env_roles object
required
Defines the collaborator's updated environment roles.
required
The type of workspace environment where you plan to update the collaborator's roles.
required
optional
WORKSPACES WITHOUT ENVIRONMENTS ENABLED
For workspaces that do not have environments enabled, use dev as the environment_type.
# Sample request
curl -X PUT 'https://www.workato.com/api/members/34567' \
  -d '{
        "env_roles": [
            "name": "Admin",
# Response
    "data": {
        "result": "ok"
# Delete a collaborator
Deletes a collaborator by their ID.
# Path parameters
id string
required
The ID of the collaborator to delete.
# Sample request
curl -X DELETE 'https://www.workato.com/api/members/34567' \
# Response
A successful request returns a 204 No Content status code. The collaborator is deleted, and the response body is empty.
# List a workspace's project grants
Retrieves all project grants for a workspace. This doesn't include project access granted through collaborator groups.
# Path parameters
id string
required
The ID of the workspace to retrieve project grants from.
# Query parameters
page object
optional
Configures pagination settings for the project grant list.
page[number] integer
optional
The page number to retrieve. The default value is 1.
page[size] integer
optional
The number of items per page to retrieve. The default and maximum value is 100.
# Sample request
curl -X GET 'https://www.workato.com/api/members/34567/project_grants?page[number]=1&page[size]=100' \
# Response
  "data": [
      "id": "pg-AQAEnmMX-b4rPeT",
      "project": {
        "id": 178230,
        "name": "Development",
        "environment": {
          "id": 148425,
          "type": "dev"
      "project_role": {
        "id": "pr-AQAEnmK3-EQpeYM",
      "id": "pg-AQAEnmKE-xpCFwT",
      "project": {
        "id": 178230,
        "name": "Sales",
        "environment": {
          "id": 148426,
          "type": "prod"
      "project_role": {
  "total": 2,
  "page": {
    "number": 1,
    "size": 100
# Get collaborator privileges
EXISTING ENDPOINT
Retrieves the privileges and roles of a collaborator by their ID. The response returns an array of roles for each environment (for example, dev, test, and prod) with the following information:
  • Environment type
  • User role
  • All permissions assigned to the role
  • Role type
The response includes roles from both the legacy model (role_type: privilege_group) and the new model (role_type: environment).
# Path parameters
id string
required
The ID of the collaborator whose privileges you plan to retrieve.
# Sample request
curl  -X GET 'https://www.workato.com/api/members/34567/privileges' \
# Response
    "data": [
            "name": "Operator",
            "role_type": "privilege_group",
            "privileges": {
                "Recipes": [
                    "read",
                    "run",
                    "read_run_history"
                "Folders": [
                    "read"
                "Projects": [
                    "read"
                "Use in recipes": [
                    "all"
                "Test automation": [
                    "read"
            "name": "Operator",
            "privileges": {
                "Recipes": [
                    "read",
                    "run",
                    "read_run_history"
                "Folders": [
                    "read"
                "Projects": [
                    "read"
                "Use in recipes": [
                    "all"
                    "read"
            "name": "Operator",
            "privileges": {
                "Recipes": [
                    "read",
                    "run",
                    "read_run_history"
                "Folders": [
                    "read"
                "Projects": [
                    "read"
                "Use in recipes": [
                    "all"
                    "read"
New properties
  "data": [
# Get collaborator projects privileges
Retrieves project-level access for a collaborator. This includes access assigned directly or through membership in a collaborator group. You can use this endpoint to audit project permissions.
# Path parameters
id string
required
The ID of the collaborator whose project privileges you plan to retrieve.
# Sample request
curl  -X GET 'https://www.workato.com/api/members/34567/projects_privileges' \
# Response
  "data": [
      "environment": {
        "id": 123456,
        "type": "dev"
      "projects": {
        "61722": {
          "Folders": ["create", "view"]
      "environment": {
        "id": 789123,
        "type": "prod"
      "projects": {
        "74137": {
          "Folders": ["view"]
# Collaborator groups
Use the following endpoints to manage your collaborator groups.
# Quick reference
GET /api/user_groups List collaborator groups.
GET /api/user_groups/:id Get collaborator group details.
POST /api/user_groups Create a collaborator group.
PUT /api/user_groups/:id Update a collaborator group.
DELETE /api/user_groups/:id Delete a collaborator group.
GET /api/user_groups/:id/members List collaborator group members.
POST /api/user_groups/:id/members Add members to a collaborator group.
DELETE /api/user_groups/:id/members Remove members from a collaborator group.
GET /api/user_groups/:id/project_grants List a collaborator group's project grants.
# List collaborator groups
Retrieves a list of collaborator groups from a workspace.
# Query parameters
name string
optional
Filter collaborator groups by their name.
page object
optional
Configures pagination settings for the group list.
optional
page[size] integer
optional
# Sample request
curl  -X GET 'https://www.workato.com/api/user_groups?page[number]=1&page[size]=100' \
# Response
  "data": [
      "description": null,
      "members_count": 5,
      "system": true,
      "created_at": "2024-08-01T13:35:11.691-07:00",
      "updated_at": "2024-08-01T13:35:11.691-07:00"
      "id": "pf-APHDLgAD-cTXBtz",
      "description": "Group for developers",
      "members_count": 2,
      "system": false,
      "created_at": "2024-08-02T13:35:11.691-07:00",
      "updated_at": "2024-08-02T13:35:11.691-07:00"
  "total": 2,
  "page": {
    "number": 1,
    "size": 100
# Get collaborator group details
SYSTEM GROUP ID
Use the List collaborator groups endpoint to retrieve the system group's ID. Each data center assigns a unique ID to the system group. You can't delete system groups.
Retrieves a collaborator group by its ID.
# Path parameters
id string
required
The ID of the collaborator group to retrieve.
# Sample request
curl  -X GET 'https://www.workato.com/api/user_groups/am-WxEKCibh-dTXBtz' \
# Response
  "data": {
    "members_count": 2,
    "system": false,
# Create a collaborator group
Creates a new collaborator group.
# Query parameters
user_group object
required
Defines the collaborator group to create.
user_group[name] string
required
The collaborator group name. The maximum length is 200 characters.
user_group[description] string
optional
The collaborator group description. The maximum length is 300 characters.
# Sample request
curl -X POST 'https://www.workato.com/api/user_groups' \
  -d '{
        "user_group": {
# Response
  "data": {
    "members_count": 1,
    "system": false,
400 BAD REQUEST
A 400 BAD REQUEST error indicates that the server couldn't process the request due to client-side issues. Common causes include malformed requests, invalid fields, or violations of field constraints, such as unsupported data types.
In the following example, the request fails because the required name parameter is blank:
  "errors": [
      "code": "bad_request",
      "title": "Name can't be blank"
# Update a collaborator group
Updates a collaborator group by its ID.
# Path parameters
id string
required
The ID of the collaborator group to update.
# Query parameters
user_group object
required
Defines the updated collaborator group.
required
The updated name of the collaborator group. The maximum length is 200 characters.
optional
The updated description of the collaborator group. The maximum length is 300 characters.
# Sample request
curl -X PUT 'https://www.workato.com/api/user_groups/am-WxEKCibh-dTXBtz' \
  -d '{
        "user_group": {
          "name": "Developers Team",
          "description": "Team"
# Response
  "data": {
    "name" : "Developers Team",
    "description": "Team",
    "members_count": 2,
    "system": false,
400 Bad Request
A 400 Bad Request error indicates that the server couldn't process the request due to client-side issues. Common causes include malformed requests, invalid fields, or violations of field constraints, such as unsupported data types.
  "errors": [
# Delete a collaborator group
Deletes a collaborator group by its ID. This automatically deletes all connections between the group and projects.
# Path parameters
id string
required
The ID of the collaborator group to delete.
# Sample request
curl  -X DELETE 'https://www.workato.com/api/user_groups/am-WxEKCibh-dTXBtz' \
# Response
A successful request returns a 204 No Content status code. The collaborator group is deleted, and the response body is empty.
# List collaborator group members
Retrieves members of a collaborator group.
# Path parameters
id string
required
The ID of the collaborator group whose members to retrieve.
# Query parameters
text string
optional
Filter members by their name or email.
page object
optional
Configures pagination settings for the member list.
optional
page[size] integer
optional
# Sample request
curl -X GET 'https://www.workato.com/api/user_groups/am-WxEKCibh-dTXBtz/members?page[number]=1&page[size]=100' \
# Response
  "data": [
      "user_id": 1,
      "member_invitation_id": null,
      "name" : "Dani",
      "type": "User",
      "avatar_url": "url"
      "user_id": null,
      "member_invitation_id": 1,
      "name" : "Alex",
      "type": "MemberInvitation",
      "avatar_url": null
  "total": 2,
  "page": {
    "number": 1,
    "size": 100
# Add members to a collaborator group
Adds collaborators to an existing collaborator group by their IDs.
# Path parameters
id string
required
The ID of the collaborator group to add members to.
# Query parameters
user_ids array of integers
required
The workspace IDs of members to add.
# Sample request
curl -X POST 'https://www.workato.com/api/user_groups/am-WxEKCibh-dTXBtz/members' \
  -d '{
        "user_ids": [1, 2]
# Response
{ "data": null }
# Remove members from a collaborator group
Removes collaborators from a collaborator group by their IDs.
# Path parameters
id string
required
The ID of the collaborator group whose members to remove.
# Query parameters
conditionally required
The IDs of members to remove from the group.
member_invitation_ids array of integers
A list of IDs for collaborator group invitations. Members who were added by the invitations are removed from the group.
CONDITIONAL REQUIREMENTS
Requests must include either user_ids or member_invitation_ids to specify which collaborators to remove from the group. You may include both to remove collaborators based on multiple criteria.
# Sample request
curl -X DELETE 'https://www.workato.com/api/user_groups/am-WxEKCibh-dTXBtz/members?user_ids[]=1&user_ids[]=2&member_invitation_ids[]=1&member_invitation_ids[]=2' \
# Response
A successful request returns a 204 No Content status code. The API removes the member from the collaborator group and returns no content in the response body.
# List a collaborator group's project grants
Retrieves project roles assigned to a collaborator group.
# Path parameters
id string
required
The ID of the collaborator group whose project grants to retrieve.
# Query parameters
page object
optional
optional
page[size] integer
optional
# Sample request
curl -X GET 'https://www.workato.com/api/user_groups/pg-AQAEnmMX-b4rPeT/project_grants?page[number]=1&page[size]=100' \
# Response
  "data": [
      "project": {
        "id": 178229,
        "environment": {
          "id": 148425,
          "type": "dev"
      "project_role": {
      "project": {
        "id": 178230,
        "environment": {
          "id": 148426,
          "type": "prod"
      "project_role": {
  "total": 2,
  "page": {
    "number": 1,
    "size": 100
# Environment roles
Use the following endpoints to manage your environment roles.
Environment roles can have the following values:
Value Definition
system Default roles provided by Workato.
custom Roles created manually within a workspace.
inheritable Custom roles from an AHQ admin or Embedded partner workspace that are inheritable by child workspaces.
inherited Roles inherited by a child workspace from its AHQ or Embedded parent.
LEGACY ROLE COMPATIBILITY
The following endpoints are only compatible with new roles where the role_type is environment.
Use the /api/roles endpoints instead to manage legacy roles where the role_type is privilege_group.
# Quick reference
GET /api/environment_roles List environment roles.
GET /api/environment_roles/:id Get environment role details.
POST /api/environment_roles Create an environment role.
PUT /api/environment_roles/:id Update an environment role.
DELETE /api/environment_roles/:id Delete an environment role.
# List environment roles
Retrieves a list of environment roles from your workspace.
# Query parameters
name string
optional
Filter environment roles by their name.
page object
optional
Configures pagination settings for the environment role list.
optional
page[size] integer
optional
# Sample request
curl -X GET 'https://www.workato.com/api/environment_roles?name=Developer&page[number]=1&page[size]=100' \
# Response
  "data": [
      "id": 1,
      "name" : "Developer",
      "members_count": 2,
      "type": "custom",
  "total": 1,
  "page": {
    "number": 1,
    "size": 100
# Get environment role details
Retrieves an environment role by its ID.
# Path parameters
id string
required
The ID of the environment role to retrieve.
# Sample request
curl -X GET 'https://www.workato.com/api/environment_roles/1' \
# Response
  "data": {
    "id": 1,
    "config": { "team": { "privileges": "all" } },
    "members_count": 2,
    "type": "custom",
# Create an environment role
Creates a new environment role.
# Query parameters
environment_role object
required
Defines the environment role to create.
environment_role[name] string
required
The name of the environment role to create. The maximum length is 200 characters.
environment_role[config] json
required
Defines the privileges assigned to the role.
environment_role[inheritable] boolean
optional
Inherits the role to child workspaces when set to true. The default value is false. This value can only be set to true in Admin AHQ or Embedded partner workspaces.
# Sample request
curl -X POST 'https://www.workato.com/api/environment_roles' \
  -d '{
        "environment_role": {
          "name": "Developer",
          "inheritable": false
# Response
  "data": {
    "id": 1,
    "members_count": 0,
    "type": "custom",
# Update an environment role
Updates an existing environment role by its ID.
# Path parameters
id string
required
The ID of the environment role to update.
# Query parameters
required
Defines the updated environment role.
required
The updated name of the environment role. The maximum length is 200 characters.
required
Defines the privileges assigned to the environment role.
optional
# Sample request
curl -X PUT 'https://www.workato.com/api/environment_roles/1' \
  -d '{
          "name": "Builder",
# Response
  "data": {
    "id": 1,
    "name" : "Builder",
    "members_count": 0,
    "type": "custom",
# Delete an environment role
Deletes an environment role by its ID.
# Path parameters
id string
required
The ID of the environment role to delete.
# Sample request
curl -X DELETE 'https://www.workato.com/api/environment_roles/1' \
# Response
A successful request returns a 204 No Content status code. The API deletes the environment role and returns an empty response body.
400 Bad Request
In the following example, the request fails because the role is still assigned to some collaborators:
  "errors": [
      "title": "You can’t delete a role when collaborators are assigned to the role."
# Project roles
Use the following endpoints to manage your project roles.
Project roles can have the following values:
Value Definition
# Quick reference
GET /api/project_roles List project roles.
GET /api/project_roles/:id Get project role details.
POST /api/project_roles Create a project role.
PUT /api/project_roles/:id Update a project role.
DELETE /api/project_roles/:id Delete a project role.
# List project roles
Retrieves a list of project roles from a workspace.
# Query parameters
name string
optional
Filter project roles by their name.
page object
optional
Configures pagination settings for the project role list.
optional
page[size] integer
optional
# Sample request
curl -X GET 'https://www.workato.com/api/project_roles?name=Builder&page[number]=1&page[size]=100' \
# Response
  "data": [
      "id": 1,
      "name" : "Builder",
      "members_count": 1,
      "type": "custom",
  "total": 1,
  "page": {
    "number": 1,
    "size": 100
# Get project role details
Retrieves a project role by its ID.
# Path parameters
id string
required
The ID of the project role to retrieve.
# Sample request
curl -X GET 'https://www.workato.com/api/project_roles/pr-APmWpgTs-dwARGH' \
# Response
  "data": {
    "id": "pr-APmWpgTs-dwARGH",
    "config": { "recipe": { "privileges": "all" } },
    "members_count": 1,
    "type": "custom",
# Create a project role
Creates a new project role.
# Query parameters
project_role object
required
Defines the project role to create.
project_role[name] string
required
The name of the project role to create. The maximum length is 200 characters.
project_role[config] json
required
project_role[inheritable] boolean
optional
# Sample request
curl -X POST 'https://www.workato.com/api/project_roles' \
  -d '{
        "project_role": {
          "name": "Builder",
# Response
  "data": {
    "name" : "Builder",
    "members_count": 0,
    "type": "custom",
# Update a project role
Updates an existing project role by its ID.
# Path parameters
id string
required
The ID of the project role to update.
# Query parameters
project_role object
required
Defines the updated project role.
required
The updated name of the project role. The maximum length is 200 characters.
required
optional
# Sample request
curl -X PUT 'https://www.workato.com/api/project_roles/pr-APmWpgTs-dwARGH' \
  -d '{
        "project_role": {
          "name": "Builder",
# Response
  "data": {
    "name" : "Builder",
    "members_count": 1,
    "type": "custom",
# Delete a project role
Deletes a project role by its ID.
# Path parameters
id string
required
The ID of the project role to delete.
# Sample request
curl -X DELETE 'https://www.workato.com/api/project_roles/pr-APmWpgTs-dwARGH' \
# Response
A successful request returns a 204 No Content status code. The API deletes the project role and returns an empty response body.
400 Bad Request
  "errors": [
# Project grants
Use the following endpoints to manage a collaborator or group's project grants.
API CLIENT ACCESS
Project grant endpoints can only assign project roles to environments and projects that the API client can access. For example, an API client assigned to the TEST environment can only manage TEST projects. Additionally, if an API client is assigned to specific projects, it can only manage those projects. Refer to Create a client role to configure an API client's access.
# What are project grants?
A project grant assigns a project role to a collaborator or group. Refer to Manage project access and roles to manage assigned project roles in the app.
# Quick reference
GET /api/project_grants/:id Get a project grant.
PUT /api/project_grants/:id Update a project grant.
DELETE /api/project_grants/:id Delete a project grant.
GET /api/projects/:id/project_grants List project grants.
PUT /api/projects/:id/project_grants Add or update project grants.
# Get a project grant
Retrieves a project grant by its ID.
# Path parameters
id string
required
The ID of the project grant to retrieve.
# Sample request
curl -X GET 'https://www.workato.com/api/project_grants/pg-AQAEnmKC-Dtt9aD' \
# Response
  "data" : {
    "id": "pg-AQAEnmKC-Dtt9aD",
    "project": {
      "id": 178229,
      "environment": {
        "id": 148425,
        "type": "dev"
    "project_role": {
      "id": "pr-AQBGCnMB-JoFtKL",
    "user_group": null,
    "user": {
      "id": 1,
      "name" : "Taylor",
# Update a project grant
Updates an existing project grant by its ID.
# Path parameters
id string
required
The ID of the project grant to update.
# Query parameters
project_grant object
required
Defines the updated project grant.
project_grant[project_role_id] string
required
The ID of the project role to assign.
# Sample request
curl -X PUT 'https://www.workato.com/api/project_grants/pg-AQAEnmKC-Dtt9aD' \
  -d '{
        "project_grant": {
          "project_role_id": "pr-AQBGCnMB-JoFtKL"
# Response
  "data" : {
    "project": {
      "id": 178229,
      "environment": {
        "id": 148425,
        "type": "dev"
    "project_role": {
    "user_group": {
      "system": false
    "user": null
400 Bad Request
In the following example, the request fails because the assignment is already taken:
  "errors": [
      "title": "Assignment has already been taken"
# Delete a project grant
Deletes a project grant by its ID.
# Path parameters
id string
required
The ID of the project grant to delete.
# Sample request
curl -X DELETE 'https://www.workato.com/api/project_grants/pg-AQAEnmKC-Dtt9aD' \
# Response
A successful request returns a 204 No Content status code. The API deletes the project grant and returns an empty response body.
# List project grants
Retrieves a list of grants from a project by its ID.
# Path parameters
id string
required
The ID of the project to retrieve grants from.
# Query parameters
page object
optional
optional
page[size] integer
optional
# Sample request
curl -X GET 'https://www.workato.com/api/projects/178229/project_grants?page[number]=1&page[size]=100' \
# Response
  "data": [
      "project_role": {
      "user": {
        "id": 1,
        "name" : "Jie",
      "user_group": null
      "project_role": {
      "user": null,
      "user_group": {
        "system": false
  "total": 2,
  "page": {
    "number": 1,
    "size": 100
# Add or update project grants
Adds or updates project grants for a project by its ID. You can include a maximum of 100 grants in each request.
# Path parameters
id string
required
The ID of the project where you plan to add or update grants.
# Query parameters
project_grants object
required
Defines project grants for the project.
project_grants[assignment_type] string
required
Specifies whether to assign the role to a workspace (User) or collaborator group (UserGroup).
project_grants[assignment_id] string
required
The ID of the target workspace or collaborator group.
project_grants[project_role_id] string
required
The ID of the role to assign.
# Sample request
curl -X PUT 'https://www.workato.com/api/projects/178229/project_grants' \
  -d '{
        "project_grants": [
            "assignment_type": "User",
            "assignment_id": "1",
            "project_role_id": "pr-AQAEnmK3-EQpeYM"
            "assignment_type": "UserGroup",
            "assignment_id": "am-WxEKCibh-dTXBtz",
# Response
{ "data": null }
400 Bad Request
In the following example, the request fails because it exceeds the maximum number of grants per request:
  "errors": [
      "title": "Max 100 project grants per request"
# Migration tool
Use the following endpoints to convert legacy roles into environment and project roles. Alternatively, you can use the in-app migration wizard.
# Quick reference
POST /api/roles_migration/system_roles Migrate system roles.
POST /api/roles_migration/custom_role Migrate a custom role.
# Migrate system roles
Converts legacy system roles into environment and project roles. You can also use the in-app migration wizard to migrate system roles.
# Query parameters
dry_run boolean
optional
Returns a JSON response without migrating roles when set to true. The default value is false.
# Sample request
curl -X POST 'https://www.workato.com/api/roles_migration/system_roles' \
# Response
  "data": {
    "environment_roles": [
        "name": "EnvironmentAdmin",
        "config": { /* environment admin configuration */ }
        "name": "EnvironmentManager",
        "config": { /* environment manager configuration */ }
        "name": "Member",
        "config": { /* member configuration */ }
    "project_roles": [
        "name": "ProjectAdmin",
        "config": { /* project admin configuration */ }
        "name": "AdvancedBuilder",
        "config": { /* advanced builder configuration */ }
       "name": "ProjectOperator",
        "config": { /* project operator configuration */ }
    "collaborators": [
        "user_id": 1,
        "name": "Kim",
        "roles": [
          { "environment": "dev", "name": "EnvironmentAdmin" },
          { "environment": "prod", "name": "EnvironmentManager" },
          { "environment": "test", "name": "Member" }
    "projects": [
        "id": 101,
        "name": "Dev Project",
        "collaborators": [
            "user_id": 1,
            "name": "Izumi",
            "project_role": "ProjectAdmin"
    "moderators": [
        "user_id": 201,
        "name": "Sasha",
        "environment_role": "EnvironmentAdmin",
# Migrate a custom role
Converts legacy custom roles into environment and project roles. Alternatively, you can use the in-app migration wizard to migrate custom roles.
# Query parameters
privilege_group_id integer
required
The ID of the role to convert.
required
required
The name of the new environment role.
environment_role[additional_permissions] object
optional
Specifies additional permissions for the new environment role.
project_role object
required
required
The name of the new project role.
project_role[additional_permissions] object
optional
Specifies additional permissions for the new project role.
dry_run boolean
optional
# Sample request
curl -X POST 'https://www.workato.com/api/roles_migration/custom_role' \
  -H "Authorization: Bearer <api_token>" \
  -d '{
        "privilege_group_id": 1,
          "name": "New Environment Role",
          "additional_permissions": {
            "manage_projects": {
              "privileges": ["create", "access_control"]
        "project_role": {
          "name": "New Project Role",
            "project_administration": {
              "privileges": ["access_control"]
# Response
  "data": {
        "name": "New environment role",
        "config": {
          "lookup_table": {
            "privileges": ["read"]
    "project_roles": [
        "name": "New project role",
        "config": {
          "recipe": {
    "collaborators": [
        "user_id": 1,
        "name": "Yuri",
        "roles": [
          { "environment": "dev", "name": "New environment role" },
          { "environment": "prod", "name": "New environment role" },
          { "environment": "test", "name": "New environment role" }
    "projects": [
        "id": 1,
        "collaborators": [
            "user_id": 1,
            "name": "Hao",
            "project_role": "New project role"
    "moderators": [
        "user_id": 1,
        "name": "Lucian",
        "environment_role": "New environment role",
Last updated: 7/16/2025, 8:12:46 PM
