# Customize login experience
You can customize the login experience for your end users by adding your primary and secondary brand colors.
Complete the following steps to customize your login experience:
Go to Workspace admin. The Access control page displays by default.
Click Login experience in the sidebar.
Go the Primary color field and enter the color hex code or click the color box to enter RBG values. This value is applied to headers, buttons, and navigational UI elements. The default color is #108291.
Default login experienceDefault login experience
Customized login experienceCustomized login experience
Go to the Secondary color field and enter the color hex code or click the color box to enter RBG values. This value is paired with your primary color for optimal contrast, such as the Login button text.
Click Save changes.
Last updated: 3/12/2026, 5:20:57 PM
