# Invite and manage workspace collaborators
You can invite, manage, and delete collaborators within a Workato workspace. Invitations add a collaborator to a workspace. It isn’t possible to invite a collaborator to only a specific project. However, you can invite a collaborator to your workspace with assigned collaborator groups that configure access to specific projects. Collaborators with project access can view the recipes, connections, and folders within those projects depending on the project role you assign and its associated privileges.
ACCESS REQUIREMENTS
You must have one of the following privileges or roles to invite and manage workspace collaborators:
- An Environment admin role or the legacy Admin system role
- A custom environment role with the Workspace access privilege
Workspaces that haven't migrated to the new access control model may still use the legacy Admin system role. After migration, equivalent permissions are granted through the Environment admin role or a custom environment role.
# Invite collaborators
PREFER VIDEO GUIDES?
Check out how to invite collaborators using this video!
Complete the following steps to invite a new collaborator to your workspace:
Go to Workspace admin > Access control > Collaborators.
Click + Invite collaborator.
Enter the Name and Email address of the collaborator.
Use the Environment role drop-down menu to select the Environment role you plan to assign. If multiple environments are enabled, you must select an environment role for each environment individually.
Add the collaborator to one or more Collaborator groups.
Click Invite to send the invitation.
INVITATION RATE LIMIT
The collaborator may receive an error if you delete and resend an invitation too quickly. This occurs due to system rate limits that block repeated invitations in a short time window.
You must wait at least 20 minutes before you resend the invitation to avoid this issue.
Users with an existing Workato account can sign in to accept the invitation. New users are prompted to create an account.
# Update a collaborator's role
You can update a collaborator’s environment role to manage their workspace-level permissions. Project-level access is managed separately within each project's settings.
USING ENVIRONMENTS
If you plan to use the Environments feature, ensure that you understand how to manage workspace roles in environments before changing a collaborator's role.
Complete the following steps to update an existing collaborator's role:
Click the collaborator you plan to modify. This opens the Edit collaborator page.
Select a new Environmental role from the drop-down menu.
Click Save changes.
# Manage a collaborator's project access
Project-level roles are managed separately from environment roles and are configured within each project's settings:
PROJECT ROLE VISIBILITY
Environment admins can assign project roles to themselves or other collaborators, even if they aren’t members of the project yet.
However, environment admins don't automatically gain access to project content. To view recipes, connections, and folders inside a project, you must first assign yourself a project role. Once assigned, you're automatically added as a project member and gain visibility based on the role’s permissions.
Open the project where you plan to manage access.
Go to Settings > Project access.
Update an existing collaborator's role using the Project role drop-down menu next to their name. Their access updates immediately.
Add a new collaborator by clicking + Add collaborators. Select the collaborators or groups, choose the appropriate Project role, and click Add to grant access.
# Delete collaborators
You can delete a collaborator from your workspace if someone has left your organization or no longer requires access to Workato.
Deleting a collaborator revokes their access but doesn’t delete any work the collaborator created, such as recipes, connections, or projects.
Complete the following steps to delete a collaborator:
Select the collaborator you plan to remove to open their details page.
Click the Delete icon.
Review the warning that their work is retained, then click Delete to confirm.
