Custom connectors
The following endpoints allow you to create and manage custom connectors, validate connector code for syntax and semantic errors, and generate a Workato Schema from sample JSON and CSV documents. The schema generation endpoints are also used in the SDK CLI tool for schema generation commands.
Rate limits
Custom connector resources have the following rate limits:
TypeResourceLimit
POSTGenerate schema from JSON:
/api/sdk/generate_schema
/json
60 requests per minute
POSTGenerate schema from CSV:
/csv
AllAll other Custom connectors endpoints1 request per second
The following additional limitations apply to custom connector resources:
DescriptionLimit
Maximum data allowed in custom connector code10 MB
Compatible code formatsUTF-8 and JSON compatible
Quick reference
The Custom connectors resource contains the following endpoints:
TypeResourceDescription
POST/api/sdk/generate_schema/jsonGenerates Workato schema from a stringified JSON sample.
POST/api/sdk/generate_schema/csvGenerates Workato schema from a stringified CSV sample.
GET/api/custom_connectors/searchSearch for custom connectors.
GET/api/custom_connectors/:id/codeFetches code for a custom connector.
POST/api/sdk/validate_codeValidates custom connector code for syntax and semantic errors.
POST/api/custom_connectorsCreates a custom connector.
POST/api/custom_connectors/:id/releaseReleases the latest version of a custom connector.
POST/api/custom_connectors/:id/shareShares a custom connector.
PUT/api/custom_connectors/:idUpdates a custom connector.
POST https://YOUR_DATA_CENTER/api/sdk/generate_schema/json
URL parameters
NameTypeDescription
samplestring
optional
Stringified JSON of the sample document to parse.
Sample request
shell
curl  -X POST https://YOUR_DATA_CENTER/api/sdk/generate_schema/json \
      --data-raw '{
     "sample": ":sample"
Response
json
        "control_type": "text",
        "label": "Test",
        "type": "string",
        "name": "test"
POST https://YOUR_DATA_CENTER/api/sdk/generate_schema/csv
URL parameters
NameTypeDescription
samplestring
optional
Stringified CSV of the sample document to parse.
col_sepstring
optional
Column delimiter for the CSV sample. Must be one of comma, semicolon, space, tab, colon, pipe.
Sample request
shell
curl  -X POST https://YOUR_DATA_CENTER/api/sdk/generate_schema/csv \
      --data-raw '{
     "sample": ":sample",
     "col_sep": ":col_sep"
Response
json
        "label": "First name",
        "type": "string",
        "name": "first_name"
        "label": "Last name",
        "type": "string",
        "name": "last_name"
Search custom connector
Searches for a custom connector in your workspace by title.
LIMITED TO TEN MOST RECENT RELEASES
Only the ten most recently released versions are returned.
GET https://YOUR_DATA_CENTER/api/custom_connectors/search
Query parameters
NameTypeDescription
titlestring
required
The title of the custom connector to search for. The search supports partial matches and is case-sensitive.
Sample request
shell
curl -X GET 'https://YOUR_DATA_CENTER/api/custom_connectors/search?title=:title' \
  -H "Authorization: Bearer <api_token>"
Sample response
json
    "data": [
            "id": 3066,
            "name": "new_connector_1_connector_4771_1626869114",
            "title": "Acme Connector",
            "logo": "<base_64 encoded logo>",
            "latest_version": 4,
            "latest_version_note": "Latest version",
            "latest_released_version": 3,
            "latest_released_version_note": null,
            "latest_shared_version": 4,
            "latest_shared_version_note": "Latest version",
            "oem_shared_version": 2,
            "oem_shared_at": "2024-02-02T08:05:22.047-07:00",
            "recent_released_versions": [
                    "version": 3,
                    "version_note": "Fixed OAuth token refresh timeout",
                    "created_at": "2024-02-08T05:05:34.136-07:00",
                    "released_at": "2024-02-08T21:33:41.713-07:00"
                    "version": 2,
                    "version_note": null,
                    "created_at": "2022-08-11T07:24:58.890-07:00",
                    "released_at": "2022-08-11T21:33:41.713-07:00"
Get custom connector code
The Get custom connector code operation allows you to fetch a custom connector's code.
GET https://YOUR_DATA_CENTER/api/custom_connectors/:id/code
URL parameters
NameTypeDescription
IDInteger requiredThe ID of the custom connector for which you plan to fetch the code. You can find your custom connector ID in the search custom connector endpoint.
Sample request
shell
curl -X GET https://YOUR_DATA_CENTER/api/custom_connectors/:id/code \
Sample response
json
  "data": {
    "code": "<connector_code_stringified>"
Validate custom connector code
Checks custom connector code for syntax and semantic errors. Use it to catch issues before you call the Create custom connector or Update custom connector endpoints.
POST https://YOUR_DATA_CENTER/api/sdk/validate_code
Payload
NameTypeDescription
codestring
required
The Ruby code for your custom connector. Ensure that the code is stringified. Your code cannot exceed 10 MB in size.
Sample request
shell
curl -X POST https://YOUR_DATA_CENTER/api/sdk/validate_code \
  -H "Authorization: Bearer <api_token>" \
  -d '{
        "code": ":code"
Sample response
An empty findings array means the code has no errors:
json
    "data": {
        "findings": []
Each finding describes one syntax or semantic error, with a docs_id you can use to look up the relevant SDK reference page:
json
    "data": {
        "findings": [
                "type": "syntax",
                "message": "(string):6:9: error: unexpected token tIDENTIFIER",
                "docs_id": "sdk:reference:ruby-methods",
                "line_from": 6,
                "column_from": 8,
                "line_to": 6,
                "column_to": 11
The Create operation allows you to create a custom connector in your workspace.
POST https://YOUR_DATA_CENTER/api/custom_connectors
Payload
NameTypeDescription
titleStringThe title of the custom connector you plan to create.
logoStringThe logo you plan to add to your custom connector. Your logo must be encoded in Base64 format.
descriptionStringA description of your custom connector. Your description is visible when you share your custom connector through a private link or through the community library. Markdown is allowed.
noteStringNotes for the initial version of your custom connector.
codeStringThe Ruby code for your custom connector. Ensure that the code is stringified. Your code cannot exceed 10MB in size.
Sample request
shell
curl -X POST https://YOUR_DATA_CENTER/api/custom_connectors \
  -d '{
    "title": ":title",
    "logo": ":logo",
    "description": ":description",
    "note": ":note",
    "code": ":code"
Sample response
json
    "id": 3066,
    "latest_version": 6,
    "latest_released_version": 4,
    "latest_shared_version": 6,
    "oem_shared_at": "2022-08-08T08:05:22.047-07:00",
    "released_versions": [
            "version": 4,
            "released_at": "2021-09-26T21:33:41.713-07:00"
            "version": 2,
            "version_note": "hello",
            "created_at": "2021-07-21T05:05:34.136-07:00",
The Update operation allows you to update a custom connector in your workspace.
PUT https://YOUR_DATA_CENTER/api/custom_connectors/:id
URL parameters
NameTypeDescription
IDInteger requiredThe ID of the custom connector you plan to update. You can find your custom connector ID in the search custom connector endpoint.
Sample request
shell
curl -X PUT https://YOUR_DATA_CENTER/api/custom_connectors/:id \
  -d '{
    "title": ":title",
    "logo": ":logo",
    "note": ":note",
    "code": ":code"
Sample response
json
    "id": 3066,
            "version": 4,
            "version": 2,
Release custom connector
The Release operation allows you to release the latest version of your custom connector. After you release the new version, it is used in all future jobs.
POST https://YOUR_DATA_CENTER/api/custom_connectors/:id/release
URL parameters
NameTypeDescription
IDInteger requiredThe ID of the custom connector you plan to release. You can find your custom connector ID in the search custom connector endpoint.
Sample request
shell
curl -X POST https://YOUR_DATA_CENTER/api/custom_connectors/:id/release \
Sample response
json
    "id": 3066,
            "version": 4,
            "version": 2,
HTTP response codes
NameDescriptionSample reply
200Success{"message": "Connector released successfully"}
400Bad request{"message": "Fix code errors before releasing the connector"} or {"message": "Connector’s released version is already the latest version"}
400 error examples
Syntax example
json
{ "errors" => [{ "code" => 400, "title" => "Line 2 has syntax errors. Please check Workato UI for further details." }] }
Semantic example
json
{ "errors" => [{ "code" => 400, "title" => "Expected string or lambda for 'description' in 'test_trigger' trigger but got Symbol." }] }
Logical example
json
{ "errors" => [{ "code" => 400, "title" => "The latest version of the custom connector is already released." }] }
Share custom connector
The Share operation allows you to share the most recently released version of your custom connector. After you share your custom connector, all workspaces that have installed your connector through a private link or from the community library receive an update notification.
POST https://YOUR_DATA_CENTER/api/custom_connectors/:id/share
URL parameters
NameTypeDescription
IDInteger requiredThe ID of the custom connector you plan to share. You can find your custom connector ID in the search custom connector endpoint.
Sample request
shell
curl -X POST https://YOUR_DATA_CENTER/api/custom_connectors/:id/share \
Sample response
json
    "id": 3066,
            "version": 4,
            "version": 2,
HTTP response codes
200Success{"message": "Connector shared successfully"}
400Bad request{"message": "There is no released version to share"} or {"message": "Connector’s shared version is already the latest released version"}
400 error examples
Logical: No released version to share example
json
{ "errors" => [{ "code" => 400, "title" => "Release the latest version of the code first" }] }
Logical: Latest release version is already shared example
json
{ "errors" => [{ "code" => 400, "title" => "The latest version of the custom connector is already shared" }] }
