Data tables
Refer to the following sections to programmatically manage data tables and their records using APIs:
Rate limits
Data table resources have the following rate limits:
TypeResourceQuota
AllAll Data tables endpoints60 requests per minute
Data center base URLs
Each data center (DC) has a dedicated base URL. Use the base URL that matches your workspace region. Select your data center in a sample request to substitute the matching base URL.
The following example shows the data-tables base URL modified for each data center:
Data centerBase URL
UShttps://data-tables.workato.com
EUhttps://data-tables.eu.workato.com
JPhttps://data-tables.jp.workato.com
SGhttps://data-tables.sg.workato.com
AUhttps://data-tables.au.workato.com
ILhttps://data-tables.il.workato.com
CNhttps://data-tables.workatoapp.cn
KRhttps://data-tables.kr.workato.com
UKhttps://data-tables.uk.workato.com
Trialhttps://data-tables.trial.workato.com
Workato returns a 403 Forbidden error if you call an endpoint that doesn't match your workspace data center.
Table management APIs
You can use the following endpoints to manage and structure data tables:
Base URL:
https://YOUR_DATA_CENTER/api
REGIONAL BASE URLS
You must use the dedicated base URL that matches your workspace region. Refer to Data center URLs for more information.
Quick reference
TypeResourceDescription
GET/api/data_tablesList all data tables.
GET/api/data_tables/:data_table_idGet data table by ID.
POST/api/data_tablesCreates a data table.
PUT/api/data_tables/:data_table_idUpdates a data table.
DELETE/api/data_tables/:data_table_idDeletes a data table.
POST/api/data_tables/:data_table_id/truncateTruncates a data table.
List data tables
Returns a list of all data tables in your workspace.
GET https://YOUR_DATA_CENTER/api/data_tables
URL parameters
NameTypeDescription
pageinteger
optional
Page number of the data tables to fetch. Defaults to 1.
per pageinteger
optional
Page size. Defaults to 100. Maximum is 100.
Sample request
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/data_tables'
Response
View a sample response
json
    "data": [
            "id": "f4d2e85d-c7f4-4877-8f16-6643a4b3fb23",
            "name": "Resume screening",
            "schema": [
                    "type": "string",
                    "name": "application_id",
                    "optional": true,
                    "field_id": "8f4a57d6-f524-47f2-ae59-be1a80dc2dd5",
                    "hint": "Greenhouse application ID",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "name": "candidate_id",
                    "optional": true,
                    "field_id": "b3f6f50a-6431-4cd4-af2c-f88a7b291bce",
                    "hint": "Greenhouse candidate ID",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "name": "job_id",
                    "optional": true,
                    "field_id": "cdf319f0-2bde-4048-bde6-4c862e7737bd",
                    "hint": "Greenhouse job ID",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "name": "department",
                    "optional": true,
                    "field_id": "25256ad2-5297-46e3-960b-f340af9d292f",
                    "hint": "Hiring department",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "name": "recruiter",
                    "optional": true,
                    "field_id": "38a85051-a12c-4f0b-a308-7e8cd5c68e78",
                    "hint": "Recruiter name",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "name": "task_name",
                    "optional": true,
                    "field_id": "a305f5b1-df86-4f3f-a434-db142c9f5b95",
                    "hint": "Workflow stage",
                    "metadata": {},
                    "multivalue": false
            "folder_id": 24468824,
            "created_at": "2025-04-04T11:35:04.544-07:00",
            "updated_at": "2025-04-04T11:55:50.473-07:00"
            "id": "fb0b03f3-2e5a-4a05-a483-4ee3092805c5",
            "name": "Intake form",
            "schema": [
                    "type": "string",
                    "name": "Description",
                    "optional": true,
                    "field_id": "b3545fa7-600c-4ed0-ab04-6e4a866db158",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "name": "Review comments",
                    "optional": true,
                    "field_id": "9db1ae98-01f2-4da5-9003-058d8ce80475",
                    "metadata": {},
                    "multivalue": false
                    "type": "number",
                    "name": "Rate",
                    "optional": true,
                    "field_id": "7b98b819-f8bc-4376-9eb1-ef18c5ca9ae1",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "name": "Notes",
                    "optional": true,
                    "field_id": "35885b91-ee7e-453e-a4f9-d41c88e74521",
                    "metadata": {},
                    "multivalue": false
                    "type": "boolean",
                    "name": "pass",
                    "optional": true,
                    "field_id": "4b0f3ac7-0dad-4628-85a8-85583c9a09d9",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "name": "Reviewer",
                    "optional": true,
                    "field_id": "a1913ee5-6342-4176-8e25-8c4787286fee",
                    "metadata": {},
                    "multivalue": false
                    "type": "file",
                    "name": "Resume",
                    "optional": true,
                    "field_id": "8853cfa6-9e69-4b57-98cb-5264497b1dac",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "name": "Email",
                    "optional": true,
                    "field_id": "fea109b6-95c2-41a9-9075-000aa4e54b6a",
                    "metadata": {},
                    "multivalue": false
            "folder_id": 21138015,
            "created_at": "2024-10-04T08:40:24.349-07:00",
            "updated_at": "2025-04-03T10:02:37.905-07:00"
            "id": "d263710a-e7cc-418f-bbc5-aacf76667418",
            "name": "PTO requests",
            "schema": [
                    "type": "string",
                    "name": "Name",
                    "optional": false,
                    "field_id": "4cd59a12-ae0c-40fa-8896-fd259b271fd9",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "optional": true,
                    "field_id": "06e65f37-81eb-4093-8219-f8b14b2b23e8",
                    "metadata": {},
                    "multivalue": false
                    "type": "string",
                    "optional": true,
                    "field_id": "cb1589c6-2537-43f8-bd5d-6776b310d080",
                    "metadata": {},
                    "multivalue": false
            "folder_id": 17415752,
            "created_at": "2024-09-26T20:49:04.147-07:00",
            "updated_at": "2024-09-26T20:49:04.222-07:00"
Returns the data table associated with the ID you specify.
GET https://YOUR_DATA_CENTER/api/data_tables/:data_table_id
URL parameters
NameTypeDescription
data_table_idinteger
required
Provide the ID of a specific data table.
Sample request
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/data_tables/:data_table_id'
Response
json
    "data": {
        "id": "db4b8544-8de8-4c6d-83bd-e487f6616ccc",
        "name": "Expense reports",
        "schema": [
                "type": "string",
                "name": "Expense type",
                "optional": false,
                "field_id": "1ec0c3c7-abcd-4bca-bab5-efa51da56635",
                "metadata": {},
                "multivalue": false
                "type": "number",
                "name": "Cost",
                "optional": true,
                "metadata": {},
                "multivalue": false
                "type": "date",
                "name": "Date of purchase",
                "optional": true,
                "metadata": {},
                "multivalue": false
                "type": "integer",
                "name": "Priority",
                "optional": true,
                "metadata": {},
                "multivalue": false
        "folder_id": 1124996,
        "created_at": "2025-05-16T13:30:09.835+08:00",
        "updated_at": "2025-05-16T13:30:09.835+08:00"
Record import status
The response also includes a records_import_status object while a record import is in progress, and for up to 24 hours after it completes or until it's dismissed. Automated pipelines can use this object to detect a failed import:
NameTypeDescription
filenamestringThe file name provided when starting the import.
total_bytesintegerThe total size of the file in bytes.
total_recordsintegerThe total number of records in the file.
statusstringThe import status, such as in_progress, completed, or failed.
processed_recordsintegerThe number of records processed so far.
etastringThe estimated time of completion. Present when status is in_progress.
completed_atstringThe time the import completed. Present when status is completed.
failed_atstringThe time the import failed. Present when status is failed.
is_internal_errorbooleanIndicates whether a failure is due to an internal Workato error rather than an error in the imported data. Present when status is failed.
errorstringA human-readable description of the failure. Present when status is failed.
error_record_idxintegerThe 0-based index of the record that caused the failure. Present when status is failed.
error_detailsobjectContains details about the failure. Present when status is failed. Refer to Error codes for the possible values.
The following example shows a completed import:
json
  "data": {
    "records_import_status": {
      "filename": "bank_report.csv",
      "total_bytes": 3005,
      "total_records": 18,
      "status": "completed",
      "processed_records": 18,
      "completed_at": "2026-07-09T17:44:42.877+00:00"
Error codes
The response contains an error_details object when status is failed, which contains an error_code field with one of the following values:
Error codeAdditional fieldsDescription
MAX_TABLE_SIZE_EXCEEDEDmax_table_size_bytesThe import would exceed the maximum table size.
MAX_NUM_RECORDS_EXCEEDEDmax_num_recordsThe import would exceed the maximum number of records per table.
MAX_DOCUMENT_SIZE_EXCEEDEDmax_document_size_bytesA record would exceed the maximum record size.
TEXT_VALUE_TOO_LONGfield_id, field_name, max_text_value_charsA text value exceeds the maximum number of characters allowed for the field.
LIMITS
Refer to Data tables - Quotas for the size and record quotas that apply to imports.
Failed import example
The import failed in the following example because a text value exceeds the maximum number of characters allowed for the description field:
json
  "data": {
      "total_bytes": 15295,
      "total_records": 1,
      "status": "failed",
      "processed_records": 0,
      "failed_at": "2026-07-13T17:05:10.565+00:00",
      "is_internal_error": false,
      "error": "value in field \"description\": text is too long (15000 characters, max allowed: 10000)",
      "error_record_idx": 0,
      "error_details": {
        "error_code": "TEXT_VALUE_TOO_LONG",
        "field_id": "4b01d22e-b888-4d1d-b90c-7c78ad75424d",
        "field_name": "description",
        "max_text_value_chars": 10000
Create data table
Creates a data table in a folder you specify.
POST https://YOUR_DATA_CENTER/api/data_tables
Payload
NameTypeDescription
namestring
required
The name of the data table to create.
folder_idinteger
required
Provide the ID of the folder where you plan to create the data table.
schemaarray
required
Supply an array of nested elements to define your table structure. You must supply the column name, data type, and whether the column is required.
schema[type]boolean, date, date_time, integer, number, string, file, relation
required
The data type of the column you plan to create.
schema[name]string
required
The name of the column you plan to create.
schema[optional]integer, boolean
required
Indicates if the column is required or optional. Must be either true, false, 1, or 0.
schema[field_id]Must match regular expression: /\h{8}-\h{4}-\h{4}-\h{4}-\h{12}/
optional
Unique Universal Identifier (UUID) of the column. Must follow this format: f47ac10b-58cc-4372-a567-0e02b2c3d479.
schema[hint]string
optional
Provide a hint to help your end users populate entries in a data column. The hint displays as a tooltip when you hover over the column in the user interface.
schema[default_value]variable
optional
The default value of the column. Must match the data type of the column specified in the request.
schema[metadata]hash
optional
Data table metadata.
schema[relation]hash
optional
Indicates that this table links to another data table.
schema[relation][table_id]string
optional
The ID of the data table linked to this table.
schema[relation][field_id]string
required
The column ID of a linked data table.
schema[multivalue]boolean optionalIndicates whether the column accepts multi-value input.
Sample request
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/data_tables' \
	  -d '{
            "name": ":name",
            "folder_id": :folder_id_value,
            "schema": [
                    "type": ":type",
                    "name": ":name",
                    "optional": :true_or_false,
                    "multivalue": :true_or_false,
                    "relation": {
                        "table_id": ":table_id",
                        "field_id": ":field_id"
Response
json
    "data": {
        "id": "52d97443-1dbd-4ae0-9cd9-99ac2d020977",
        "name": "Expense reports 4",
        "schema": [
                "type": "string",
                "optional": false,
                "field_id": "76ddbd6f-35ea-4884-bb97-cecac5d4abc7",
                "metadata": {},
                "multivalue": true,
                "relation": {
                    "table_id": "2507a39a-6847-4857-88ed-c3b9c8302e02",
                    "field_id": "900454f4-5b3d-4670-bc3c-d640915156f2"
Update data table
Updates a data table you specify.
PUT https://YOUR_DATA_CENTER/api/data_tables/:data_table_id
URL parameters
NameTypeDescription
data_table_idstringThe ID of the data table you plan to update. You can use the List data tables endpoint to retrieve data table IDs.
Payload
NameTypeDescription
namestring
required
folder_idstring
optional
schemaarray
required
required
schema[name]string
required
required
optional
schema[hint]string
optional
optional
optional
optional
optional
required
Sample request
shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/data_tables/:data_table_id' \
	  -d '{
            "name": ":name",
            "schema": [
                    "type": ":type",
                    "name": ":name",
                    "relation": {
Response
json
    "data": {
        "name": "Expense reports updated",
        "schema": [
                "type": "string",
                "optional": false,
                "field_id": "318b18ca-bb5f-426c-adb1-74eb2fc06641",
                "default_value": [],
                "metadata": {},
                "multivalue": true
                "type": "date",
                "name": "Date",
                "optional": true,
                "field_id": "97a960ee-022b-4a69-bcdb-74bb4c3d524d",
                "metadata": {},
                "multivalue": false
                "type": "boolean",
                "name": "Status",
                "optional": true,
                "field_id": "66b7f251-b874-4d87-a974-c18260a6a8fb",
                "metadata": {},
                "multivalue": false
                "type": "date_time",
                "name": "Check-in",
                "optional": true,
                "field_id": "6c119dad-3d08-427d-bac2-27536aedebad",
                "metadata": {},
                "multivalue": false
                "type": "file",
                "name": "Reciept",
                "optional": true,
                "field_id": "a6e5360f-5b5e-4261-9967-4160bd80e1a0",
                "metadata": {},
                "multivalue": false
                "type": "integer",
                "name": "Length of stay in days",
                "optional": true,
                "field_id": "bea282f0-fc78-4847-b7c8-a93587835faa",
                "metadata": {},
                "multivalue": false
                "type": "number",
                "name": "Cost",
                "optional": true,
                "field_id": "7d438888-5e04-4b70-b7b1-e54cdc42e877",
                "metadata": {},
                "multivalue": false
                "type": "relation",
                "name": "Budget",
                "optional": true,
                "field_id": "ebe23be4-d388-42fd-922b-0fb4e57abc08",
                "metadata": {},
                "relation": {
                "multivalue": false
        "folder_id": 75509,
        "created_at": "2025-05-21T14:56:49.173-07:00",
        "updated_at": "2025-05-21T15:36:23.701-07:00"
Delete data table
Deletes a data table you specify.
DELETE https://YOUR_DATA_CENTER/api/data_tables/:data_table_id
URL parameters
NameTypeDescription
required
Data table ID.
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_CENTER/api/data_tables/:data_table_id'
Response
json
    "data": {
        "status": "success"
Truncate data table
Truncates a data table you specify. Truncating a data table deletes all data from a data table, but doesn't effect the table structure.
POST https://YOUR_DATA_CENTER/api/data_tables/:data_table_id/truncate
URL parameters
NameTypeDescription
required
Data table ID.
Sample request
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/data_tables/:data_table_id/truncate'
Response
json
    "data": {
        "status": "success"
Record manipulation APIs
You can use the following endpoints to create, delete, and update data table records. Refer to the OpenAPI specification at /api/v1/openapi.json on the base URL for your data center.
Base URL:
https://YOUR_DATA_TABLES_DC/api
REGIONAL BASE URLS
Quick reference
POST/api/v1/tables/:data_table_id/queryQueries records using filters you specify.
POST/api/v1/tables/:data_table_id/recordsCreates a new record.
PUT/api/v1/tables/:data_table_id/records/:record_idUpdates an existing record.
DELETE/api/v1/tables/:data_table_id/records/:record_idDeletes a record you specify.
POST/api/v1/tables/:data_table_id/fields/:field_id/fileGenerates a link to upload a file.
GET/api/v1/tables/:data_table_id/records/:record_id/fields/:field_id/fileGenerates a link to download a file.
Query records (v1)
Queries records in a data table based on filters you specify.
POST https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/query
URL parameters
NameTypeDescription
Payload
NameTypeDescription
selectarray
optional
Provide the list of columns to be retrieved from the data table.
wherehash
optional
Set of conditions to filter the records with. Refer to the where clause section for more information.
orderstring or hash
optional
The column to order the results with. Provide either a string, or a hash for more advanced ordering configuration. Detailed breakdown of the hash structure can be found below.
timezone_offset_secsinteger
optional
The time zone offset for query. Required if the query includes comparison of a date-time field to a date value.
limitinteger
optional
Limits the number of records to return per page. The maximum is 200.
continuation_tokenstring
optional
Provide the next page token from previous page's request to fetch the next set of results of the same query.
INFO
The following meta-fields can be used in order parameters with the fields you created: $record_id, $created_at, and $updated_at.
where field structure
A basic where clause uses the following format:
{ <field>: { <operator>: <value> } }
You can set the <value> to a primitive value or an object.
The following table lists available operator values:
OperatorDescriptionExample
$eqEqual{ "name": { "$eq": "Josh" } }
$neNot equal{ "status": { "$ne": "inactive" } }
$gteGreater than or equal to{ "score": { "$gte": 75 } }
$gtGreater than{ "score": { "$gt": 90 } }
$lteLess than or equal to{ "amount": { "$lte": 13 } }
$ltLess than{ "amount": { "$lt": 10 } }
$inIn (returns records where value matches any of the items in the <value>){ "name": { "$in": ["Josh", "Bob", "Alice"] } }
$starts_withStarts with{ "email": { "$starts_with": "admin@" } }
Compound conditions
You can combine multiple conditions with $and compound operator using the format { "$and": [ <condition1>, <condition2>, ... ] }. For example:
json
  "$and": [
      "name": "Josh"
      "id": {
        "$lte": 13
Alternatively, you can use the equivalent short-hand notation for the $and operator. For example:
json
  "name": "Josh",
  "id": { "$lte": 13 }
order field hash structure
You must use the following structure when you provide a hash for the order field:
json
  "by": <field>,
  "direction": "asc" | "desc",
  "case_sensitive": true | false
Sample request
shell
curl  -X POST 'https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/query' \
	  -d '{
            "select": [":select_column_1", ":select_column_2"],
            "where":
                    ":where_field_1": { "$gt": :where_value_1 },
                    ":where_field_2": ":where_value_2"
            "order": ":order",
            "limit": :limit_value,
            "timezone_offset_secs": :timezone_offset_secs_value
Response
json
  "schema": [
    [ // Metafields
      { "name": "$record_id" },
      { "name": "$created_at" },
      { "name": "$updated_at" }
    [ // Fields
      { "name": "Name", "id": "2507a39a-6847-4857-88ed-c3b9c8302e02" },
      { "name": "Address", "id": "4705a22b-9139-6482-332a-ca2dd2d03sd3" },
  "data": [
    [ // Record 1
      [ // Metafields
        "e9498300-1ea3-4bf0-bdea-ffe58c101bcf",
        "2025-08-19T17:53:48.073+00:00",
      [ // Fields
        "Ann-Marie Tan",
        "5 Pennsylvania Ave. S320123"
    [ // Record 2
      [ // Metafields
        "900454f4-5b3d-4670-bc3c-d640915156f2",
      [ // Fields
        "John Paul Lim",
        "8 Somapah Road S210492"
  "count": 2,
  "limit": 10
Create record (v1)
Creates a record in a specified data table.
POST https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records
URL parameters
NameTypeDescription
data_table_idstringThe ID of the data table where you plan to create the record. You can use the List data tables endpoint to retrieve data table IDs.
Payload
The structure of the request payload is a key-value pair of each field. You can specify fields by their UUIDs (dollar-escaped) or names. Fields not listed in the schema are replaced with default values. Extra fields that aren't included in the schema are ignored.
Sample request
shell
curl  -X POST 'https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records' \
	  -d '{
            "document":
                ":field_name_1": ":field_value_1",
                ":field_name_2": :field_value_2,
                ":$field_id_uuid": :field_value_3,
                ":field_name_date": ":field_value_date",
                ":field_name_relation":
                        "record_id": ":record_id"
                ":field_name_file":
                        "filename": ":filename",
                        "upload_id": ":upload_id"
Response
json
    "data": {
        "record_id": "ab0189ca-fadf-4382-a48b-e157d966078f",
        "created_at": "2025-07-10T15:55:02.661+00:00",
        "updated_at": "2025-07-10T15:55:02.661+00:00",
        "document": [
                "field_id": "42d62e3b-895d-43db-b8f7-cbb62dac71dd",
                "field_name": "name",
                "value": "Josh"
                "field_id": "2dca773b-eb67-4201-924d-4ccb9d577e99",
                "field_name": "multivalue",
                "value": [1,2,3]
                "field_id": "28c00d59-7dbe-4134-85be-937513500500",
                "field_name": "age",
                "value": 13
                "field_id": "0489bb65-7072-404f-9bba-e3e94a2a527b",
                "field_name": "date",
                "value": "2022-02-01"
                "field_id": "d6f103d9-575f-41b9-9ef0-b70e8fe38cc8",
                "field_name": "relation",
                "value": {
                    "record_id": "7a13304c-14cf-4e98-be31-331ccdb2b253",
                    "value": "Parent"
                "field_id": "f71f1f67-0de5-422c-be73-b27b12f442c4",
                "field_name": "file",
                "value": {
                    "filename": "birth_certificate.txt"
Update record (v1)
Updates a record in a specified data table.
PUT https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/:record_id
URL parameters
NameTypeDescription
data_table_idstringThe ID of the data table where the record resides. You can use the List data tables endpoint to retrieve data table IDs.
record_idstringThe ID of the record to be updated.
Payload
The structure of the request payload is a key-value pair of each field. You can specify fields by their UUIDs (dollar-escaped) or names. Fields not listed in the schema aren't updated. Extra fields that aren't included in the schema are ignored.
Sample request
shell
curl  -X PUT 'https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/:record_id' \
	  -d '{
            "document":
                ":field_name_file":
Response
json
    "data": {
        "document": [
                "value": "Josh"
                "value": [1,2,3]
                "value": 13
                "value": {
                    "value": "Parent"
                "value": {
Delete record (v1)
Deletes a record in a specified data table.
DELETE https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/:record_id
URL parameters
NameTypeDescription
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/:record_id'
Response
Workato returns status code 200 without a response payload if the deletion is successful.
Generates a link to upload a file for file-type columns. Use the resulting upload_id when you create or update a record.
POST https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/fields/:field_id/file
NameTypeDescription
field_idstringThe ID of the file column for the file to be uploaded.
shell
curl  -X POST 'https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/fields/:field_id/file' \
json
  "data" : {
    "upload_id": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
    "url": "https://file-storage.workato.com/sharing/files?sign=eyJ0eXAiOiJKV1QiLCJhbGciOiJFUzI1NiJ9.eyJpc3MiOiJXb3JrYXRvRmlsZXMiLCJhdWQiOiJ3b3JrYXRvX2ZpbGVzIiwiZXhwIjoxNzUzOTUzNTUzLCJuYmYiOjE3NTM5NTI2NTMsInN1YiI6IjY5MjY1OCIsImp0aSI6IjBmMzY4N2EyLTUzNGUtNGIxMC1iODQzLTk4NmU1MWI2YTI1MCIsIm9iaiI6eyJtZXRob2QiOiJHRVQiLCJyZXNvdXJjZSI6ImY0YWE3OWU0MjlhZjNjNGRhNTcwMGU0NTYxMTY3MzM2ZjMzOTJmNzNkZDQ0ZjhjMGExMTk4MDI5MmViNzE2NjMiLCJjb25zdHJhaW50cyI6eyJmaWxlX21heF9ieXRlcyI6bnVsbCwiZmlsZV9wYXRoIjoiL1Rlc3RpbmcvMi1zdGVwLWxvZ2luLWVucm9sbG1lbnQyMDI1LTA2LTI3VDAyMzE0Ni5odG1sIiwiZmlsZV90dGwiOm51bGwsIm5hbWVzcGFjZSI6ImFkYXB0ZXIiLCJzaGFyaW5nX2FwaV9raW5kIjoicHVibGljIiwidXNlcl9pZCI6NjkyNjU4fX19.0p-NuNaQxCs_VaTaWsQGg5aS3BwCGSrHSQOVh5xb-jXQAaHAv_RSnUs6ymV9IHMVZM2P1ikodSDGtyn7pqZItw"
Download file from the record (v1)
Generates a link to download the file in the file-type column of a record.
GET https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/:record_id/fields/:field_id/file
URL parameters
NameTypeDescription
record_idstringThe ID of the record linked to the file.
field_idstringThe ID of the file column of the file to be downloaded.
Sample request
shell
curl -X GET 'https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/:record_id/fields/:field_id/file'
Response
Workato returns a 303 status code with the download URL inside the LOCATION header if the request is successful.
Record import APIs
You can use the following endpoints to import records into a data table from a file.
The following example shows a typical import flow:
Import flow
Create a file upload link to request a signed URL for the file.
Upload the file to the returned URL, sending the raw file bytes as the body.
Optional. Describe the uploaded file to inspect the detected columns and record count before importing.
Add any missing columns to the table with the Update data table endpoint. The table must already contain the columns you map to. Importing into a table with no matching columns fails.
Start the import, mapping file columns to table fields.
Monitor the import through the records_import_status field of the Get data table by ID endpoint.
Dismiss the import to clear the import state, or call it earlier to cancel.
REGIONAL BASE URLS
Quick reference
POST/api/v1/tables/:data_table_id/records/import/file/upload_linkCreates a link to upload a file.
POST/sharing/filesUploads the file to the signed link.
DELETE/api/v1/tables/:data_table_id/records/import/fileDeletes the uploaded file.
GET/api/v1/tables/:data_table_id/records/import/fileDescribes the uploaded file.
POST/api/v1/tables/:data_table_id/records/import/startStarts importing records from the uploaded file.
DELETE/api/v1/tables/:data_table_id/records/importDismisses or cancels the import.
Creates a signed link you use to upload a file for import.
POST https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/import/file/upload_link
NameTypeDescription
data_table_idstring
required
The ID of the data table to import records into. You can use the List data tables endpoint to retrieve data table IDs.
NameTypeDescription
file_formathash
required
The format of the file to upload.
file_format[format]string
required
The file format. Only csv is currently supported.
file_format[has_header]boolean
required
Whether the file has column labels in the first row.
file_format[delimiter]string
required
The character used to separate values in a row. Accepted values are comma, semicolon, space, tab, colon, and pipe.
file_format[quote]string
required
The character used to quote values that contain the delimiter character or newlines. Accepted values are double and single.
file_format[encoding]string
required
The text encoding name. Supported encodings are those defined in the WHATWG Encoding Standard. For example, utf-8.
shell
curl -X POST 'https://YOUR_DATA_TABLES_DC/api/v1/tables/58408ccc-e209-491b-9873-4549b5fa48df/records/import/file/upload_link' \
     -d '{
           "file_format": {
             "format": "csv",
             "has_header": true,
             "delimiter": "comma",
             "quote": "double",
             "encoding": "utf-8"
Returns 201 Created with the signed Workato Files URL you use to upload the file.
json
  "data": {
    "url": "https://file-storage.workato.com/sharing/files?sign=<signed_token>"
Import already in progress
The request returns a 400 Bad Request error with the IMPORT_STATE_ERROR code in the following example because an import is already in progress for the table:
json
  "errors": [
    { "code": "IMPORT_STATE_ERROR", "title": "import already in progress" }
Table not found
The request returns a 404 Not Found error in the following example because the data table doesn't exist or is outside your scope:
json
  "errors": [
    { "code": "TABLE_NOT_FOUND" }
Upload file
Upload the file to the signed URL returned by Create file upload link. This endpoint doesn't require an Authorization header. The signature in the URL authorizes the request.
Base URL: the host returned in the url field of Create file upload link
POST /sharing/files
Query parameters
NameTypeDescription
signstring
required
The authorizing signature returned by Create file upload link.
Payload
Send the raw file bytes as the request body.
Sample request
shell
curl -X POST 'https://file-storage.workato.com/sharing/files?sign=<signed_token>' \
     -H 'Content-Type: text/csv' \
     --data-binary @data.csv
Response
json
  "file_id": "7d1ac9a4-2a6c-4951-b97a-9ab22c722500",
  "mime_type": "text/csv",
  "path": "/csv_import.4546638.c9228d13-f394-44ff-a3a2-13e04a70ea9c.csv",
  "size": 3005,
  "version_id": null
Delete uploaded file
Deletes the file that was uploaded for import. Use this to cancel before starting an import.
DELETE https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/import/file
URL parameters
NameTypeDescription
data_table_idstring
required
The ID of the data table from which to delete the uploaded file.
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_TABLES_DC/api/v1/tables/58408ccc-e209-491b-9873-4549b5fa48df/records/import/file' \
Response
Returns 200 OK with an empty data object.
json
  "data": {}
No uploaded file
The request returns a 400 Bad Request error with the IMPORT_STATE_ERROR code in the following example because a file wasn't uploaded for import:
json
  "errors": [
    { "code": "IMPORT_STATE_ERROR", "title": "import file not found" }
Table not found
json
  "errors": [
Describe uploaded file
Returns the columns and record count detected in the uploaded file so you can review them before starting the import.
GET https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/import/file
URL parameters
NameTypeDescription
data_table_idstring
required
The ID of the data table from which to describe an uploaded file.
Sample request
shell
curl -X GET 'https://YOUR_DATA_TABLES_DC/api/v1/tables/58408ccc-e209-491b-9873-4549b5fa48df/records/import/file' \
Response
json
  "data": {
    "columns": [
        "column_id": "col1",
        "label": "report_date",
        "optional": false,
        "type": "date",
        "valid_types": ["date", "string"]
        "column_id": "col9",
        "label": "amount",
        "optional": false,
        "type": "number",
        "valid_types": ["number", "string"]
    "file_format": {
      "encoding": "utf-8",
      "format": "csv",
      "has_header": true,
      "quote": "double"
    "num_records": 18
No uploaded file
json
  "errors": [
Table not found
json
  "errors": [
Start import
Starts importing records from the uploaded file into the table.
PREREQUISITES
The Start import endpoint has the following prerequisites:
  • Upload a file with the Upload file endpoint.
  • Ensure all table columns exist in the target destination. Add any missing columns with the Update data table endpoint before starting the import.
POST https://YOUR_DATA_TABLES_DC/api/v1/tables/:data_table_id/records/import/start
URL parameters
NameTypeDescription
data_table_idstring
required
Payload
NameTypeDescription
filenamestring
required
The file name shown in the UI for this import.
fieldsarray
required
The mapping between file columns and table fields. Each entry maps one file column to one table field. All required table fields must be mapped, and the column and field data types must be compatible.
fields[field_id]string
conditional
The ID of the target table field. Provide either field_id or field_name.
fields[field_name]string
conditional
The name of the target table field. Provide either field_id or field_name.
fields[file_column_index]integer
conditional
The 0-based index of the source file column. Provide either file_column_index or file_column_label.
fields[file_column_label]string
conditional
The label of the source file column. You can use this only when the column label is unique in the file. Provide either file_column_index or file_column_label.
modestring
required
The import behavior. Accepted values are assert_table_empty, truncate_table, and append. Refer to Import modes for more information.
Import modes
The following import modes are supported:
ModeBehavior
assert_table_emptyThe import proceeds only if the table is empty. Otherwise, it returns an error.
truncate_tableAll existing records are deleted before importing. Requires the Truncate a data table permission.
appendRecords are appended to the existing records in the table.
Sample request
shell
curl -X POST 'https://YOUR_DATA_TABLES_DC/api/v1/tables/58408ccc-e209-491b-9873-4549b5fa48df/records/import/start' \
     -d '{
           "filename": "data.csv",
           "fields": [
             { "field_name": "report_date", "file_column_label": "report_date" },
             { "field_name": "amount", "file_column_label": "amount" },
             { "field_name": "currency", "file_column_label": "currency" }
           "mode": "append"
Response
Returns 202 Accepted with an empty data object when the import is successfully initiated. Track import progress with the records_import_status field of the Get data table by ID endpoint.
json
  "data": {}
Import can't be started
The request returns a 400 Bad Request error with the IMPORT_STATE_ERROR code when the import can't start. For example, when a file wasn't uploaded, an import is already in progress, or the table isn't empty in assert_table_empty mode. The table isn't empty in the following example:
json
  "errors": [
    { "code": "IMPORT_STATE_ERROR", "title": "table has records" }
Incompatible field mapping
The request returns a 400 Bad Request error with the IMPORT_SCHEMA_ERROR code when the mapping is invalid. For example, due to an unknown column, a duplicate mapping, or an unmapped required field. A file column type doesn't match the target field type in the following example:
json
  "errors": [
    { "code": "IMPORT_SCHEMA_ERROR", "title": "column \"Name\" (index 0) is not compatible with the type \"date\" of table field \"date_registered\" (9a2d5844-a983-43c7-b7c0-217c570b445a)" }
Table not found
json
  "errors": [
Dismiss import
Dismisses the import state after an import completes, or cancels an in-progress import.
URL parameters
NameTypeDescription
data_table_idstring
required
The ID of the data table from which to dismiss or cancel an import.
Sample request
shell
curl -X DELETE 'https://YOUR_DATA_TABLES_DC/api/v1/tables/58408ccc-e209-491b-9873-4549b5fa48df/records/import' \
Response
json
  "data": {}
No import to dismiss
The request returns a 400 Bad Request error with the IMPORT_STATE_ERROR code in the following example because no imports have started for the table:
json
  "errors": [
    { "code": "IMPORT_STATE_ERROR", "title": "import not started" }
Table not found
json
  "errors": [
