# Portal settings
Go to Platform > Workflow apps portal > Portal settings to configure the Workflow apps portal. The Portal settings tab includes the following sections:
# General
VIRTUAL PRIVATE WORKATO (VPW) CUSTOMERS
This feature requires configuration steps that are specific to your Virtual Private Workato (VPW) instance. If you are a VPW customer, refer to your VPW private documentation for the configuration details for your instances.
This section enables you to set up the Portal name and customize the Portal URL by choosing a unique URL prefix.
  • Portal name
  • Business name of your Workflow apps portal. Workato displays the portal name in the App portal and email notifications.
  • Portal URL
  • Customize the URL prefix. The data center you use determines where the Workflow apps portal is hosted. Example: https://acme.workato.app
    • US Data Center:
    • workato.app
    • EU Data Center:
    • eu.workato.app
    • SG Data Center:
    • sg.workato.app
    • JP Data Center:
    • jp.workato.app
    • AU Data Center:
    • au.workato.app
    • IL Data Center:
    • il.workato.app
    • Developer sandbox:
    • trial.workato.app
# Branding
This section enables you to customize the Workflow apps portal to include your brand logo, change branding colors to match your organization, and configure a custom font.
  • Brand logo
  • Supports PNG and SVG file types.
    • Maximum size:
    • 10 mb.
  • Brand color
  • Choose a color for the headers, buttons, and navigational elements. You can enter a hex color code or use the color picker.
    • Sample value:
    • #739ad9
  • Complementary text color
  • Pair a complementary color with the brand color to optimize contrast. You can enter a hex color code or use the color picker.
    • Sample value:
    • #d3ce31
  • Google Fonts URL
  • Enter a Google Fonts URL to apply a custom font to the Workflow apps portal. Custom fonts don't apply to Workflow apps email notifications.
# Preview
The Preview feature enables you to preview how the Brand color, Complementary text color, and Brand logo work together before implementing them in your Workflow apps portal.
The preview is static and contained within the Settings interface.
Preview your branding choicesPreview your branding choices for the Workflow apps portal
# Custom domain and email server
You can set up a custom domain and email server for your Workflow apps portal. Refer to the Custom domain and email server documentation for more information.
# Security
The security section enables you to set up authentication for the portal and control whether portal pages can be embedded in external websites.
# Authentication
Workato supports the following authentication schemes:
Security settingsSet up security settings for the Workflow apps portal
# Embedding
You can embed portal pages into your organization's internal portals, Salesforce, and more.
Toggle Enable iframe embedding to allow embedding your portal pages in an iframe. From here, you can enable embedding your portal pages in any iframe, or only within domains you specify.
If you plan to limit embedding your portal pages only to specific domains, you can specify one or more URLs in the Specify frame ancestors field. These URLs are used in the Content-Security-Policy HTTP header to allow rendering of Workflow apps in an iframe.
Alternatively, leave this field blank to allow embedding pages in any iframe.
Specify domainsEnable embedding
# Customize portal for embedding
When you embed portal pages within external sites, you can customize the portal's appearance by hiding the top banner and customizing the padding on all sides by appending specific query parameters to your portal URL.
These parameters are URL-encoded JSON in the following format:
Example:
{"showHeader": false, "layoutPadding": "0 10px 10px 0"}
  • showHeader
  • Boolean (true/false) value. Set to false to hide the top header of the portal.
  • layoutPadding
  • Determine the padding of the portal on all sides. In the preceding example, the top padding is 0, the right is 10px, the bottom is 10px, and the left is 0.
The following demonstrates how to generate the parameter value in your browser console:
encodeURIComponent(JSON.stringify({"showHeader": false, "layoutPadding": "0 10px 10px 0"}))
Which results in the following parameter. Append this to your portal URL:
?embedding_params=%7B%22showHeader%22%3Afalse%2C%22layoutPadding%22%3A%220%200%200%200%22%7D
Altogether, it looks something like this:
<iframe src="https://mycompany.workato.app/app-name/?embedding_params=%7B%22showHeader%22%3Afalse%2C%22layoutPadding%22%3A%220%200%200%200%22%7D"></iframe>
Last updated: 3/25/2026, 11:29:38 AM
