Automation HQ settings
Automation HQ provides audit log streaming to help administrators stream logs from all managed workspaces into a single destination.
You can configure audit log streaming for the entire organization in the Settings. The following log types are available to stream:
- Job status only: Logs whether a job succeeded or failed.
- Full job details: Logs job details, including status and data for each line action.
- User activity: Logs all user activity in the workspace.
- API platform logs: Logs all API requests handled by the API platform.
- Workato Log events: Logs all messages sent to the Workato logging service.
- Genie conversations: Logs the full details of genie conversations, including data for every response.
You can also customize log messages and select the destination for logs. Workato supports the following destinations:
- Amazon S3 Bucket
- Azure Monitor
- Azure Blob
- A cloud-based logging service, such as Sumo Logic, Datadog, Splunk, or Google Cloud Storage Buckets
Audit log streaming is disabled by default. Refer to Audit log streaming for Automation HQ to configure audit log streaming.
Workspace settings
Cross-workspace grants
Cross-workspace grants let source workspaces share Event streams topics with other managed workspaces in your Automation HQ organization.
You can enable cross-workspace grants for the entire organization in the Settings interface.
Cross-workspace grants are disabled by default. Refer to Enable cross-workspace grants to configure this setting.
FURTHER READING
